In the menu "Services -> UPS" the drop down menu list for the driver selection is too small. Some drivers have a longer description than fits in the drop-down menu. So they can hardly be read.
The drop down menu should be wider.
And one more thing. I didn't find any entry for my Eaton Ellipse Pro 850 UPS.
According to this site:
I can use the usbhid-ups driver. But there was no entry in the driver drop down menu list for usbhid-ups generic either.
So i ended up in selecting the entry "Eaton ups 5 Ellipse ECO 650/800/1200/1600 VA USB (usbhid-ups)." because Ellipse ECO sounded closes to Ellipse Pro and
it had the (usbhid-ups) driver name in brackets, but it was not readable in the drop down menu list.
The driver seems to work for my Eaton Ellipse Pro 850 so far, but it would be much better if there would be a menu entry for my
Eaton Ellipse Pro 850. I will need further testing, if everything works right.
usbconfig says about my UPS the following, i hope this information is useful for you:
usbconfig -d ugen0.2 dump_all_desc ugen0.2: <EATON Ellipse PRO> at usbus0, cfg=0 md=HOST spd=LOW (1.5Mbps) pwr=ON (20mA) bLength = 0x0012 bDescriptorType = 0x0001 bcdUSB = 0x0110 bDeviceClass = 0x0000 <Probed by interface class> bDeviceSubClass = 0x0000 bDeviceProtocol = 0x0000 bMaxPacketSize0 = 0x0008 idVendor = 0x0463 idProduct = 0xffff bcdDevice = 0x0100 iManufacturer = 0x0001 <EATON> iProduct = 0x0002 <Ellipse PRO> iSerialNumber = 0x0004 <##########> bNumConfigurations = 0x0001 Configuration index 0 bLength = 0x0009 bDescriptorType = 0x0002 wTotalLength = 0x0022 bNumInterfaces = 0x0001 bConfigurationValue = 0x0001 iConfiguration = 0x0000 <no string> bmAttributes = 0x00a0 bMaxPower = 0x000a Interface 0 bLength = 0x0009 bDescriptorType = 0x0004 bInterfaceNumber = 0x0000 bAlternateSetting = 0x0000 bNumEndpoints = 0x0001 bInterfaceClass = 0x0003 <HID device> bInterfaceSubClass = 0x0000 bInterfaceProtocol = 0x0000 iInterface = 0x0000 <no string> Additional Descriptor bLength = 0x09 bDescriptorType = 0x21 bDescriptorSubType = 0x10 RAW dump: 0x00 | 0x09, 0x21, 0x10, 0x01, 0x21, 0x01, 0x22, 0x79, 0x08 | 0x04 Endpoint 0 bLength = 0x0007 bDescriptorType = 0x0005 bEndpointAddress = 0x0081 <IN> bmAttributes = 0x0003 <INTERRUPT> wMaxPacketSize = 0x0008 bInterval = 0x0014 bRefresh = 0x0000 bSynchAddress = 0x0000
