FreeNAS-11.2-U8
CPU: Intel i3-6100
MEM: Samsung 16GB DDR4 2133 ECC X8 2R (M391A2K43BB1-CPB)
MBO: Supermicro X11SSL-CF
Data: 6x Toshiba DT01ACA300 + 1 hot spare
Boot: Samsung 830 SSD
PSU: Corsair RM750x
Encrypted poll with a passphrase already set.
After a long time, I've had a drive drop out. It seems similar to my previous issues with compatibility between the Toshiba DT01ACA3 drives and the LSI 3008. The error is slightly different now, but I'm not sure if it's due to FreeNAS and HBA FW updates, or if this latest one is unrelated.
FreeNAS HDD issue:
Zpool status:
SMART:
The Reallocated Sector Count isn't ideal so the drive might actually be failing, but I have a suspicion the dropout might be due to above mentioned compatibility issue.
Is the SMART error issue big enough to retire the drive regardless?
My main question is regarding the replacement procedure. I've read the manual and some of the answers on the forum, but I still am not 100% I got the procedure right.
The manual states:
Is this the correct procedure:
1. Changet ADA3 from REMOVED to OFFLINE
2. Shutdown and replace ADA3 with a new drive OR simply restart if ADA3 is presumed ok
3. Boot, Go to Storage ➞ Pools. Locate the encrypted pool and click (Settings) ➞ Status. Find the disk to replace and click (Options) ➞ Replace. Enter the passphrase that was set for the pool, then click REPLACE DISK. (Will it allow me to replace the disk with itself?)
4. Immediately (don't wait for the resilver to complete) Click (Encryption Options) ➞ Add Recovery Key and enter the root password to save the new recovery key
This is where I get confused. Do I have to then do the "The pool can be rekeyed by clicking (Encryption Options) ➞ Encryption Rekey." or is that optional?
What about the currently active hot spare during all this? Will FreeNAS revert it automatically back to hot spare and I just ignore it during the whole procedure?
CPU: Intel i3-6100
PSU: Corsair RM750x
FreeNAS HDD issue:
Mar 24 06:03:23 NAS1 ahcich3: Timeout on slot 14 port 0 Mar 24 06:03:23 NAS1 ahcich3: is 00000000 cs 00004000 ss 00000000 rs 00004000 tfd d0 serr 00000000 cmd 0004ce17 Mar 24 06:03:23 NAS1 (ada3:ahcich3:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:03:23 NAS1 (ada3:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:03:23 NAS1 (ada3:ahcich3:0:0:0): Retrying command Mar 24 06:03:56 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:04:26 NAS1 ahcich3: Timeout on slot 15 port 0 Mar 24 06:04:26 NAS1 ahcich3: is 00000000 cs 00000000 ss 00000000 rs 00008000 tfd 150 serr 00000000 cmd 0004cf17 Mar 24 06:04:26 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:04:26 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:04:26 NAS1 (aprobe0:ahcich3:0:0:0): Retrying command Mar 24 06:06:22 NAS1 ahcich3: Timeout on slot 2 port 0 Mar 24 06:06:22 NAS1 ahcich3: is 00000000 cs 00000004 ss 00000000 rs 00000004 tfd d0 serr 00000000 cmd 0004c217 Mar 24 06:06:55 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:07:25 NAS1 ahcich3: Timeout on slot 3 port 0 Mar 24 06:07:25 NAS1 ahcich3: is 00000000 cs 00000008 ss 00000000 rs 00000008 tfd 80 serr 00000000 cmd 0004c317 Mar 24 06:07:25 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:07:25 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:07:25 NAS1 (aprobe0:ahcich3:0:0:0): Retrying command Mar 24 06:08:16 NAS1 ahcich3: Timeout on slot 9 port 0 Mar 24 06:08:16 NAS1 ahcich3: is 00000000 cs 00000000 ss 0000fffc rs 0000fffc tfd 50 serr 00000000 cmd 0004cf17 Mar 24 06:08:16 NAS1 (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 48 11 01 40 2d 00 00 01 00 00 Mar 24 06:08:16 NAS1 (ada3:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:08:16 NAS1 (ada3:ahcich3:0:0:0): Retrying command Mar 24 06:09:26 NAS1 ahcich3: Timeout on slot 23 port 0 Mar 24 06:09:26 NAS1 ahcich3: is 00000000 cs 00800000 ss 00000000 rs 00800000 tfd d0 serr 00000000 cmd 0004d717 Mar 24 06:09:26 NAS1 (ada3:ahcich3:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:09:26 NAS1 (ada3:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:09:26 NAS1 (ada3:ahcich3:0:0:0): Retrying command Mar 24 06:10:06 NAS1 ahcich3: Timeout on slot 11 port 0 Mar 24 06:10:06 NAS1 ahcich3: is 00000000 cs 00000800 ss 00000000 rs 00000800 tfd d0 serr 00000000 cmd 0004cb17 Mar 24 06:10:06 NAS1 (ada3:ahcich3:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:10:06 NAS1 (ada3:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:10:06 NAS1 (ada3:ahcich3:0:0:0): Retrying command Mar 24 06:10:39 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:11:09 NAS1 ahcich3: Timeout on slot 12 port 0 Mar 24 06:11:09 NAS1 ahcich3: is 00000000 cs 00000000 ss 00000000 rs 00001000 tfd 150 serr 00000000 cmd 0004cc17 Mar 24 06:11:09 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:11:09 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:11:09 NAS1 (aprobe0:ahcich3:0:0:0): Retrying command Mar 24 06:11:41 NAS1 ahcich3: Timeout on slot 1 port 0 Mar 24 06:11:41 NAS1 ahcich3: is 00000000 cs 00000000 ss 00000006 rs 00000006 tfd 50 serr 00000000 cmd 0004c217 Mar 24 06:11:41 NAS1 (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 c8 3a 7f 40 2d 00 00 01 00 00 Mar 24 06:11:41 NAS1 (ada3:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:11:41 NAS1 (ada3:ahcich3:0:0:0): Retrying command Mar 24 06:12:39 NAS1 ahcich3: Timeout on slot 26 port 0 Mar 24 06:12:39 NAS1 ahcich3: is 00000000 cs 04000000 ss 00000000 rs 04000000 tfd d0 serr 00000000 cmd 0004da17 Mar 24 06:12:39 NAS1 (ada3:ahcich3:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:12:39 NAS1 (ada3:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:12:39 NAS1 (ada3:ahcich3:0:0:0): Retrying command Mar 24 06:13:12 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:13:42 NAS1 ahcich3: Timeout on slot 27 port 0 Mar 24 06:13:42 NAS1 ahcich3: is 00000000 cs 08000000 ss 00000000 rs 08000000 tfd 80 serr 00000000 cmd 0004db17 Mar 24 06:13:42 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:13:42 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:13:42 NAS1 (aprobe0:ahcich3:0:0:0): Retrying command Mar 24 06:14:15 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:14:45 NAS1 ahcich3: Timeout on slot 28 port 0 Mar 24 06:14:45 NAS1 ahcich3: is 00000000 cs 10000000 ss 00000000 rs 10000000 tfd 80 serr 00000000 cmd 0004dc17 Mar 24 06:14:45 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:14:45 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:14:45 NAS1 (aprobe0:ahcich3:0:0:0): Error 5, Retries exhausted Mar 24 06:15:18 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:15:48 NAS1 ahcich3: Timeout on slot 29 port 0 Mar 24 06:15:48 NAS1 ahcich3: is 00000000 cs 20000000 ss 00000000 rs 20000000 tfd 80 serr 00000000 cmd 0004dd17 Mar 24 06:15:48 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:15:48 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:15:48 NAS1 (aprobe0:ahcich3:0:0:0): Error 5, Retry was blocked Mar 24 06:15:48 NAS1 ada3 at ahcich3 bus 0 scbus4 target 0 lun 0 Mar 24 06:15:48 NAS1 ada3: <TOSHIBA DT01ACA300 MX6OABB0> s/n 1234ABCD detached Mar 24 06:16:02 NAS1 GEOM_ELI: g_eli_write_done() failed (error=6) gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli[WRITE(offset=225280, length=4096)] Mar 24 06:16:02 NAS1 GEOM_ELI: g_eli_write_done() failed (error=6) gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli[WRITE(offset=487424, length=4096)] Mar 24 06:16:02 NAS1 GEOM_ELI: g_eli_read_done() failed (error=6) gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli[READ(offset=270336, length=8192)] Mar 24 06:16:02 NAS1 GEOM_ELI: g_eli_read_done() failed (error=6) gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli[READ(offset=2998444761088, length=8192)] Mar 24 06:16:02 NAS1 GEOM_ELI: g_eli_read_done() failed (error=6) gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli[READ(offset=2998445023232, length=8192)] Mar 24 06:16:02 NAS1 GEOM_ELI: g_eli_write_done() failed (error=6) gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli[WRITE(offset=2998444978176, length=4096)] Mar 24 06:16:02 NAS1 GEOM_ELI: g_eli_write_done() failed (error=6) gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli[WRITE(offset=2998445240320, length=4096)] Mar 24 06:16:02 NAS1 GEOM_MIRROR: Device swap2: provider ada3p1 disconnected. Mar 24 06:16:02 NAS1 ZFS: vdev state changed, pool_guid=1367972315423497889 vdev_guid=8011460992587928332 Mar 24 06:16:03 NAS1 GEOM_ELI: Device gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli destroyed. Mar 24 06:16:03 NAS1 GEOM_ELI: Detached gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli on last close. Mar 24 06:16:03 NAS1 (ada3:ahcich3:0:0:0): Periph destroyed Mar 24 06:16:03 NAS1 ada3 at ahcich3 bus 0 scbus4 target 0 lun 0 Mar 24 06:16:03 NAS1 ada3: <TOSHIBA DT01ACA300 MX6OABB0> ATA8-ACS SATA 3.x device Mar 24 06:16:03 NAS1 ada3: Serial Number 1234ABCD Mar 24 06:16:03 NAS1 ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Mar 24 06:16:03 NAS1 ada3: Command Queueing enabled Mar 24 06:16:03 NAS1 ada3: 2861588MB (5860533168 512 byte sectors) Mar 24 06:16:19 NAS1 ZFS: vdev state changed, pool_guid=1367972315423497889 vdev_guid=8011460992587928332 Mar 24 06:16:19 NAS1 ZFS: vdev state changed, pool_guid=1367972315423497889 vdev_guid=3439061830581111410 Mar 24 06:16:19 NAS1 GEOM_ELI: Device mirror/swap2.eli destroyed. Mar 24 06:16:19 NAS1 GEOM_MIRROR: Device swap2: provider destroyed. Mar 24 06:16:19 NAS1 GEOM_MIRROR: Device swap2 destroyed. Mar 24 06:16:49 NAS1 ahcich3: Timeout on slot 31 port 0 Mar 24 06:16:49 NAS1 ahcich3: is 00000000 cs 00000000 ss 80000001 rs 80000001 tfd 50 serr 00000000 cmd 0004c017 Mar 24 06:16:49 NAS1 (ada3:ahcich3:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 80 fc 3f 40 00 00 00 01 00 00 Mar 24 06:16:49 NAS1 (ada3:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:16:49 NAS1 (ada3:ahcich3:0:0:0): Retrying command Mar 24 06:17:21 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:17:51 NAS1 ahcich3: Timeout on slot 1 port 0 Mar 24 06:17:51 NAS1 ahcich3: is 00000000 cs 00000002 ss 00000000 rs 00000002 tfd 80 serr 00000000 cmd 0004c117 Mar 24 06:17:51 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:17:51 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:17:51 NAS1 (aprobe0:ahcich3:0:0:0): Retrying command Mar 24 06:18:22 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:18:52 NAS1 ahcich3: Timeout on slot 2 port 0 Mar 24 06:18:52 NAS1 ahcich3: is 00000000 cs 00000004 ss 00000000 rs 00000004 tfd 80 serr 00000000 cmd 0004c217 Mar 24 06:18:52 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:18:52 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:18:52 NAS1 (aprobe0:ahcich3:0:0:0): Error 5, Retries exhausted Mar 24 06:19:23 NAS1 ahcich3: AHCI reset: device not ready after 31000ms (tfd = 00000080) Mar 24 06:19:53 NAS1 ahcich3: Timeout on slot 3 port 0 Mar 24 06:19:53 NAS1 ahcich3: is 00000000 cs 00000000 ss 00000000 rs 00000008 tfd 150 serr 00000000 cmd 0004c317 Mar 24 06:19:53 NAS1 (aprobe0:ahcich3:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00 Mar 24 06:19:53 NAS1 (aprobe0:ahcich3:0:0:0): CAM status: Command timeout Mar 24 06:19:53 NAS1 (aprobe0:ahcich3:0:0:0): Error 5, Retry was blocked Mar 24 06:19:53 NAS1 ada3 at ahcich3 bus 0 scbus4 target 0 lun 0 Mar 24 06:19:53 NAS1 ada3: <TOSHIBA DT01ACA300 MX6OABB0> s/n 1234ABCD detached Mar 24 06:19:54 NAS1 smartd[3617]: Device: /dev/ada3, failed to read SMART Attribute Data Mar 24 06:19:54 NAS1 savecore: /dev/ada1p1: Operation not permitted Mar 24 06:19:54 NAS1 g_access(944): provider ada3 has error 6 set Mar 24 06:19:54 NAS1 g_access(944): provider ada3 has error 6 set Mar 24 06:19:54 NAS1 g_access(944): provider ada3 has error 6 set Mar 24 06:19:54 NAS1 (ada3:ahcich3:0:0:0): Periph destroyed Mar 24 06:19:54 NAS1 ada3 at ahcich3 bus 0 scbus4 target 0 lun 0 Mar 24 06:19:54 NAS1 ada3: <TOSHIBA DT01ACA300 MX6OABB0> ATA8-ACS SATA 3.x device Mar 24 06:19:54 NAS1 ada3: Serial Number 1234ABCD Mar 24 06:19:54 NAS1 ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Mar 24 06:19:54 NAS1 ada3: Command Queueing enabled Mar 24 06:19:54 NAS1 ada3: 2861588MB (5860533168 512 byte sectors) Mar 24 06:19:57 NAS1 GEOM_MIRROR: Device mirror/swap2 launched (2/2). Mar 24 06:19:57 NAS1 GEOM_ELI: Device mirror/swap2.eli created. Mar 24 06:19:57 NAS1 GEOM_ELI: Encryption: AES-XTS 128 Mar 24 06:19:57 NAS1 GEOM_ELI: Crypto: hardware
Zpool status:
[root@NAS1 ~]$ zpool status
pool: DBR-pool1
state: DEGRADED
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: resilvered 1.93T in 0 days 04:52:05 with 0 errors on Wed Mar 24 11:08:16 2021
NAME STATE READ WRITE CKSUM
DBR-pool1 DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
gptid/7442e5da-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0
spare-1 REMOVED 0 0 0
8011460992587928332 REMOVED 0 0 0 was /dev/gptid/2c59d96f-7a1f-11e8-9c02-0cc47a868d02.eli
gptid/36f62083-7d28-11e8-949e-0cc47a868d02.eli ONLINE 0 0 1.36K
mirror-1 ONLINE 0 0 0
gptid/7dd9ce06-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0
gptid/813153f4-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
gptid/8790b712-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0
gptid/8af9d490-31c0-11e8-80b9-0cc47a868d02.eli ONLINE 0 0 0
spares
6616561076194790823 INUSE was /dev/gptid/36f62083-7d28-11e8-949e-0cc47a868d02.eli
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:16 with 0 errors on Thu Mar 18 03:45:16 2021
freenas-boot ONLINE 0 0 0
ada2p2 ONLINE 0 0 0
SMART:
root@NAS1:~ # smartctl -x /dev/ada3
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Toshiba 3.5" DT01ACA... Desktop HDD
Device Model: TOSHIBA DT01ACA300
Serial Number: 1234ABCD
LU WWN Device Id: 5 000039 fe3d2e1b4
Firmware Version: MX6OABB0
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Mar 24 12:04:44 2021 CET
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Disabled
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (22508) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 376) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0
2 Throughput_Performance P-S--- 140 140 054 - 68
3 Spin_Up_Time POS--- 151 151 024 - 365 (Average 395)
4 Start_Stop_Count -O--C- 100 100 000 - 135
5 Reallocated_Sector_Ct PO--CK 100 100 005 - 6
7 Seek_Error_Rate PO-R-- 078 078 067 - 3670016
8 Seek_Time_Performance P-S--- 124 124 020 - 33
9 Power_On_Hours -O--C- 097 097 000 - 26629
10 Spin_Retry_Count PO--C- 100 100 060 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 135
192 Power-Off_Retract_Count -O--CK 099 099 000 - 1626
193 Load_Cycle_Count -O--C- 099 099 000 - 1632
194 Temperature_Celsius -O---- 181 181 000 - 33 (Min/Max 17/47)
196 Reallocated_Event_Count -O--CK 100 100 000 - 15
197 Current_Pending_Sector -O---K 100 100 000 - 0
198 Offline_Uncorrectable ---R-- 100 100 000 - 0
199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x03 GPL R/O 1 Ext. Comprehensive SMART error log
0x04 GPL R/O 7 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x08 GPL R/O 2 Power Conditions log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x20 GPL R/O 1 Streaming performance log [OBS-8]
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed without error 00% 26568 -
# 2 Extended offline Completed without error 00% 26504 -
# 3 Short offline Completed without error 00% 26472 -
# 4 Short offline Completed without error 00% 26377 -
# 5 Short offline Completed without error 00% 26281 -
# 6 Short offline Completed without error 00% 26185 -
# 7 Extended offline Interrupted (host reset) 80% 26116 -
# 8 Short offline Completed without error 00% 26089 -
# 9 Short offline Completed without error 00% 25993 -
#10 Short offline Completed without error 00% 25897 -
#11 Extended offline Completed without error 00% 25833 -
#12 Short offline Completed without error 00% 25801 -
#13 Short offline Completed without error 00% 25705 -
#14 Short offline Completed without error 00% 25609 -
#15 Short offline Completed without error 00% 25513 -
#16 Extended offline Completed without error 00% 25449 -
#17 Short offline Completed without error 00% 25417 -
#18 Short offline Completed without error 00% 25345 -
#19 Short offline Completed without error 00% 25249 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 256 (0x0100)
SCT Support Level: 1
Device State: SMART Off-line Data Collection executing in background (4)
Current Temperature: 33 Celsius
Power Cycle Min/Max Temperature: 28/36 Celsius
Lifetime Min/Max Temperature: 17/47 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -40/70 Celsius
Temperature History Size (Index): 128 (24)
Index Estimated Time Temperature Celsius
25 2021-03-24 09:57 33 **************
... ..( 4 skipped). .. **************
30 2021-03-24 10:02 33 **************
31 2021-03-24 10:03 34 ***************
32 2021-03-24 10:04 34 ***************
33 2021-03-24 10:05 34 ***************
34 2021-03-24 10:06 33 **************
... ..( 15 skipped). .. **************
50 2021-03-24 10:22 33 **************
51 2021-03-24 10:23 34 ***************
... ..( 2 skipped). .. ***************
54 2021-03-24 10:26 34 ***************
55 2021-03-24 10:27 33 **************
... ..( 7 skipped). .. **************
63 2021-03-24 10:35 33 **************
64 2021-03-24 10:36 34 ***************
... ..( 6 skipped). .. ***************
71 2021-03-24 10:43 34 ***************
72 2021-03-24 10:44 33 **************
... ..( 28 skipped). .. **************
101 2021-03-24 11:13 33 **************
102 2021-03-24 11:14 34 ***************
103 2021-03-24 11:15 33 **************
... ..( 16 skipped). .. **************
120 2021-03-24 11:32 33 **************
121 2021-03-24 11:33 34 ***************
122 2021-03-24 11:34 34 ***************
123 2021-03-24 11:35 34 ***************
124 2021-03-24 11:36 33 **************
... ..( 27 skipped). .. **************
24 2021-03-24 12:04 33 **************
SCT Error Recovery Control:
Read: Disabled
Write: Disabled
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 135 --- Lifetime Power-On Resets
0x01 0x010 4 26629 --- Power-on Hours
0x01 0x018 6 96059608892 --- Logical Sectors Written
0x01 0x020 6 429892287 --- Number of Write Commands
0x01 0x028 6 190742716163 --- Logical Sectors Read
0x01 0x030 6 705245995 --- Number of Read Commands
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 26625 --- Spindle Motor Power-on Hours
0x03 0x010 4 26625 --- Head Flying Hours
0x03 0x018 4 1632 --- Head Load Events
0x03 0x020 4 6 --- Number of Reallocated Logical Sectors
0x03 0x028 4 579 --- Read Recovery Attempts
0x03 0x030 4 7 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 7 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 33 --- Current Temperature
0x05 0x010 1 33 N-- Average Short Term Temperature
0x05 0x018 1 32 N-- Average Long Term Temperature
0x05 0x020 1 47 --- Highest Temperature
0x05 0x028 1 17 --- Lowest Temperature
0x05 0x030 1 43 N-- Highest Average Short Term Temperature
0x05 0x038 1 25 N-- Lowest Average Short Term Temperature
0x05 0x040 1 42 N-- Highest Average Long Term Temperature
0x05 0x048 1 25 N-- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 513 --- Number of Hardware Resets
0x06 0x010 4 288 --- Number of ASR Events
0x06 0x018 4 0 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0009 2 19 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 13 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
The manual states:
9.5.1.1. Replacing an Encrypted Disk
If the ZFS pool is encrypted, additional steps are needed when replacing a failed drive.
Ensure a passphrase has been set before attempting to replace the failed drive. To replace a drive in an encrypted pool,
- Go to Storage ➞ Pools. Locate the encrypted pool and click (Settings) ➞ Status. Find the disk to replace and click (Options) ➞ Replace. Enter the passphrase that was set for the pool, then click REPLACE DISK.
- Click (Encryption Options) ➞ Add Recovery Key and enter the root password to save the new recovery key. The old recovery key will no longer function and can be safely discarded.
