Disconnected drive?
leonardorame
Hi, I logged in to a TrueNAS-12.0-U4.1 and noticed a warning saying one of 3 disk RaidZ1 was REMOVED. I rebooted the system and the disk went back online, resilver and now everything looks ok.
After that I took a look at /var/log/messages and found this:
Jul 29 17:38:18 gauss ahcich2: Timeout on slot 22 port 0
Jul 29 17:38:18 gauss ahcich2: is 00000000 cs 00400000 ss 00000000 rs 00400000 tfd c0 serr 00000000 cmd 0000d617
Jul 29 17:38:18 gauss (ada1:ahcich2:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
Jul 29 17:38:18 gauss (ada1:ahcich2:0:0:0): CAM status: Command timeout
Jul 29 17:38:18 gauss (ada1:ahcich2:0:0:0): Retrying command, 0 more tries remain
Jul 29 17:38:48 gauss ahcich2: Timeout on slot 7 port 0
Jul 29 17:38:48 gauss ahcich2: is 00000000 cs 00000080 ss 00000000 rs 00000080 tfd c0 serr 00000000 cmd 0000c717
Jul 29 17:38:48 gauss (ada1:ahcich2:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
Jul 29 17:38:48 gauss (ada1:ahcich2:0:0:0): CAM status: Command timeout
Jul 29 17:38:48 gauss (ada1:ahcich2:0:0:0): Retrying command, 0 more tries remain
Jul 29 17:39:19 gauss ahcich2: Timeout on slot 18 port 0
Jul 29 17:39:19 gauss ahcich2: is 00000000 cs 00040000 ss 00000000 rs 00040000 tfd c0 serr 00000000 cmd 0000d217
Jul 29 17:39:19 gauss (ada1:ahcich2:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
Jul 29 17:39:19 gauss (ada1:ahcich2:0:0:0): CAM status: Command timeout
Jul 29 17:39:19 gauss (ada1:ahcich2:0:0:0): Retrying command, 0 more tries remain
Jul 29 17:39:51 gauss ahcich2: AHCI reset: device not ready after 31000ms (tfd = 00000080)
Jul 29 17:40:14 gauss 1 2021-07-29T17:40:14.617732-03:00 gauss.truenas.local smartd 1552 - - Device: /dev/ada1, failed to read SMART Attribute Data
Jul 29 17:40:14 gauss ada1 at ahcich2 bus 0 scbus2 target 0 lun 0
Jul 29 17:40:14 gauss ada1: <WDC WD20EFRX-68EUZN0 82.00A82> s/n WD-WCC4M3JPNPJJ detached
Jul 29 17:40:15 gauss (ada1:ahcich2:0:0:0): Periph destroyed
Jul 29 17:40:19 gauss (aprobe0:ahcich2:0:0:0): NOP FLUSHQUEUE. ACB: 00 00 00 00 00 00 00 00 00 00 00 00
Jul 29 17:40:19 gauss (aprobe0:ahcich2:0:0:0): CAM status: ATA Status Error
Jul 29 17:40:19 gauss (aprobe0:ahcich2:0:0:0): ATA status: d1 (BSY DRDY SERV ERR), error: 04 (ABRT )
Jul 29 17:40:19 gauss (aprobe0:ahcich2:0:0:0): RES: d1 04 ff ff ff ff ff ff ff ff ff
Jul 29 17:40:19 gauss (aprobe0:ahcich2:0:0:0): Error 5, Retries exhausted
Jul 30 00:00:00 gauss syslog-ng[1288]: Configuration reload request received, reloading configuration;
Jul 30 00:00:00 gauss syslog-ng[1288]: Configuration reload finished;
Jul 31 00:00:00 gauss syslog-ng[1288]: Configuration reload request received, reloading configuration;
Jul 31 00:00:00 gauss syslog-ng[1288]: Configuration reload finished;
To me it looks like a cabling or power supply problem, but do you see anything else?.
Id be very leery of this disk with a Z1 pool. Keep an eye on it for sure. If TN kicks it from the pool, something is hokey.
leonardorame
Just started a long Smart test on all disks, just to see if something is wrong in any of the disks.
HarambeLives
From the output, it looks like this is a 2TB SATA Disk. For the cost of a 2TB disk, I'd just toss this one honestly
But, that's just me
