GET PLUGINS FAILED.
IzLogan
Everytime i click on the plugins section or install plugins i get an error.
"Cmd('git') failed due to: exit code(128) cmdline: git clone -v https://github.com/freenas/iocage-ix-plugins.git /mnt/ada02pool/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git stderr: 'Cloning into '/mnt/ada02pool/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git'... fatal: unable to access 'https://github.com/freenas/iocage-ix-plugins.git/': Could not resolve host: github.com ' "
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 1504, in _clone_repo
repo = git.Repo(destination)
File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 131, in __init__
raise NoSuchPathError(epath)
git.exc.NoSuchPathError: /mnt/ada02pool/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
await self.future
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 388, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 409, in available
plugins_versions_data = IOCPlugin(branch=branch, git_repository=plugin_repository).fetch_plugin_versions()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 220, in fetch_plugin_versions
self.pull_clone_git_repo()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 133, in pull_clone_git_repo
depth, self.callback
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 1569, in _clone_repo
k: v for k, v in kwargs.items() if v
File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 988, in clone_from
return cls._clone(git, url, to_path, GitCmdObjectDB, progress, **kwargs)
File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 939, in _clone
finalize_process(proc, stderr=stderr)
File "/usr/local/lib/python3.7/site-packages/git/util.py", line 333, in finalize_process
proc.wait(**kwargs)
File "/usr/local/lib/python3.7/site-packages/git/cmd.py", line 415, in wait
raise GitCommandError(self.args, status, errstr)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(128)
How can i fix this issue
Alecmascot
William Bravin
Hello all
Read this post. I have the same problem.
However i do not understand what how to fix this
In the GUI under Network | Global Configuration, make sure you have at least one nameserver and the IPv4 Default Gateway filled in.
William Bravin
Hi Tanks for replying so quickly I do have 192.168.1.1 in that location to no avail
evassieger
TrueNAS-12.0-RC1
Does anyone have any answers?
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
    await self.future
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 399, in __run_body
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/jail_freebsd.py", line 367, in available
    return self.middleware.call_sync('plugin.available_impl', options).wait_sync(raise_error=True)
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 332, in wait_sync
    raise CallError(self.error)
middlewared.service_exception.CallError: [EFAULT] filedescriptor out of range in select()
Alecmascot
TrueNAS-12.0-RC1
    await self.future
You do not have the same problem.
The OP has a Name Resolution problem. Yours is completely different.
Have you set a location for plugins and jails
khajo
await self.future
proc.wait(**kwargs)
just make sure that your nameserver and gateway are correct and online
vinjoza
Does anyone else have the problem of evassieger 3 posts up?
I have TrueNAS 12.0, fresh install. My nameserver and gateway are correct, online, and restarted. Problem persists.
error message when entering external services, like fetching Plugins:
await self.future
please help, I don't want to reinstall
William Bravin
hello all
i do not say i am an it guy.
however in my limited knowledge, what i did to resolve my issue was to perform an iocage clean -a reboot freenas 11.3 and proceeded to reinstall the plugins. following this my plugins worked
sorry i could not be of more help
vinjoza
hello all
Thank you... That would make me re-initialize nextcloud where I have sync set up with out people who work from-home. But it's a big step up from having to reinstall all, set up all shares, rebuild pools etc.
Hoping for a less painful fix, still, thank you a lot
-Mael-
I have the exact same issue with the same error message. I'm on TrueNAS 12.0. The plugin page had been working for some time after the upgrade to 12.0 and has only started failing in the last week.
UPDATE - A reboot fixed my issue.
SOLVED: Be sure to set at least one DNS server address and your default gateway address. It is *important* to restart your server for the change to have an effect. The DNS server address that I used was 209.18.47.61 & 209.18.47.62 . You can also try 1.1.1.1 & 8.8.8.8 . My default gateway address was 192.168.1.1 . You can find your default gateway address in Command Prompt with the command 'ipconfig /all' or by checking your router. Also make sure that your DHCP is 'no' in interfaces.
