TremorAcePV
- Jun 20, 2013
I'm posting this here because I'm not sure if these fall into the same category.
What I'm trying to accomplish that brought up the above questions:
Do I need to have a task set up for both PUSH & PULL for the rsync to work, or just one? If only one, which one?
The documentation says the following about this:
This implies to me that I am supposed to make a single rsync task on the PUSH.
However, in the Rsync with SSH section, it says this at the end of the section:
Do they work differently? Why would it say, in general, to put the task on the PUSH, then with SSH, put one on the PULL? I take it that means you need two, one for each side, but from examples I've seen, people only make a single task.
To configure rsync, you need to configure both ends of the connection:
- the rsync server: this system pulls (receives) the data. This system is referred to as PULL in the configuration examples.
- the rsync client: this system pushes (sends) the data. This system is referred to as PUSH in the configuration examples.
If you are synchronizing data between two FreeNAS® systems, create the rsync task on the rsync client.
You are now ready to create the rsync task on PULL.
The SSH service was set to On (sshd was running).
I used ssh-keygen multiple times in trying to get SSH to work. The id_rsa & *.pub version were created. Then I added the private key from id_rsa to the Host Private Key in the SSH Service settings. I realized after some reading that is not what you are supposed to do.
Has this changed the user or host private SSH keys?
After realizing I was doing everything wrong, I deleted known_hosts, authorized_keys, & id_rsa (pub & private) from the /root/.ssh directory, and removed the user private key from the Host Private Key section of the SSH Service's settings.
Am I back to what a fresh install of FreeNAS with SSH's service turned on would be like, or did this change things in other files, such as the ssh_host*_key files in /etc/ssh?
I'm basically trying to figure out how to get rsync over SSH working, then I want to figure out a way to get that working over WAN as securely as possible. Not sure if I should try VPN, port forwarding, or what, but I should do it one step at a time.
Unfortunately, I don't know enough about any of these things (rsync, SSH, & VPNs/Port forwarding) yet, so I'm not making much progress unfortunately.
