I've configured ftp as per the directions within the documentation i've found online.
I'm able to successfully connect to the ftp using filezilla from within my network. I've changed the port from the default 21 to 21021, and am able to connect to the freenas ftp from within my network.
I've setup port forwarding on my router, rebooted the router & freenas- remote into a offsite computer, and try to ftp back to my freenas using my external WAN IP address with no luck.
Can someone help me figure this out? Maybe fire off suggestions on how to troubleshoot. Any help would be appreciated.
Thanks-
Matlock
*extra info- i'm using freenas 8.2 beta, I had freenas 8.0.4 prior, and was able to setup freenas without any issue but since installing the 8.2 beta fresh and revisiting this ftp stuff, i'm having these issues. Not sure if 8.2 beta is the issue-
Thanks-
Matlock
