Folks,
I'm almost giving up for the protocol FTP in FreeNAS.
I have the following equips: modem TP-Link TD-8817 (in bridge mode) with a TP-Link router WD1043ND.
Using my local network (home network), using Filezilla I have full access to the FTP.
But I would like to use this protocol using a dynamic IP service like “No-Ip.com” to access my FreeNAS from outside (i.e. I have a filial office in other city, and I would like to get my files from my home)
So I did a simulation: this router has a USB port and within their utilities could be done: share storage, media server and FTP. So, I forwarded the port 2222 and stuck a flash drive in, and was ready, check this out:
I'm having full access to my flash drive using a “internal” FTP.
I thought, "must be an internal protocol of this router, you enough simply placing any port, and enter the ip : port on the browser and… that’s it", so I did another simulation.
I decided to open any port on the router for my notebook and see if everything it is ok. I opened the port 2121 (TCP and UDP) to the ip 192.168.0.102 (this is my notebook ip). Look:
Well, then I thought, "now instead of putting the ip 192.168.0.102 I set the 192.168.0.107 which is where I access my FreeNAS" and I forward port 21212 for this:
Well, on my FreeNAS my FTP setup is like this:
*(The instructions are in Portuguese, but the purpose is to show what is on and how it is configured)...
I couldn’t test access by Filezilla outside my network. But I couldn’t access my server using my local network.
When I get into Filezilla and put only the ip 192.168.0.107:21212 I have full access, but when I put my no-ip (example.no-ip.org) domain, no chance!!!
The log message in Filezilla is:
Error: The connection time limit exceeded
Error: Could not connect to server
Before, I believed that I couldn’t unlock the ports, now I don’t have that certainty, I starting believe I’m setting something wrong in FreeNAS.
Could you help me with this? What could I be doing wrong?
Need a lot of help from you guys, ok?
Note:
- Using the build: FreeNAS-8.0.4-RELEASE-x64 (10351)
- Version: FreeBSD 8.2-RELEASE-p6
- Hostname: freenas.local
- Services: CIFS, Dynamic DNS, FTP, SSH, TFTPT active, the rest all off.
- FreeNAS log:
Apr 14 20:41:26 freenas ntpd[1625]: ntpd 4.2.4p5-a (1)
Apr 14 20:41:27 freenas proftpd[1813]: 127.0.0.1 - ProFTPD 1.3.3e (maint) (built Wed Feb 29 2012 00:21:12 UTC) standalone mode STARTUP
Apr 14 20:41:31 freenas INADYN[1950]: W: DYNDNS: Error 'RC_IP_CONNECT_FAILED' (0x13) when talking to IP server
Apr 14 20:41:31 freenas INADYN[1950]: W:'RC_IP_CONNECT_FAILED' (0x13) updating the IPs. (it 0)
Thanks
Note:
- FreeNAS log:
Thanks
