Dopamin3
- Aug 18, 2017
edit- SOLVED: upgraded to 2700X and freezing went away. See my last post for more details.
I've searched a lot on this topic but wanted to make my own thread for my specifics. Every 1 - 5 days my system just locks up with whatever output on the screen (usually the FreeNAS options and some messages about interfaces going up or down depending on what I'm doing). It doesn't respond to any keyboard input, can't ping or reach anything on it, and a hard shutdown and power on gets it running again. My system specs are:
Mostly it freezes at idle or very low load, sometimes it freezes when doing SMB transfers of larger files (5GB+). I can't find any relevant information in logs when this happens. When I search Ryzen in Redmine there are a bunch of done or closed bugs. I know a lot of people had issues on earlier FreeNAS with Ryzen, but how is 11.2-U5 working out for anyone with Ryzen? I think I've done enough testing to rule out my hardware, and it's just another Ryzen specific issue but I'm open to hear other opinions on what additional troubleshooting can be done. Is there any hope for 11.3 or future versions to fix me or is it just a lost cause trying to get this setup stable?
- SuperMicro SuperChassis 933T-R760B- a 3U rack mount server case with 15 hot swappable SATA and triple redundant 760W power supply. Plenty of airflow.
- Asrock X370 Taichi- latest BIOS 5.80 but same issue on all previous
- AMD Ryzen 1700- with 2700X stock cooler aka Wraith Prism. Typically idles around 30C and doesn't go above 60C under heavy load.
- 4 x 16GB Crucial CT16G4WFD8266 ECC RAM
- Visiontek 5450 GPU
- 10x Toshiba X300 5TB Hard Drives in RAIDZ3- no encryption, all 10 running off motherboard (eight from chipset , two from Asmedia controller)
- Samsung PM961 128GB NVME SSD- boot drive (formerly on mirrored flash drives with same behavior)
- FreeNAS 11.2-U5
