The FreeNAS serves up both. I primarily use iSCSI, NFS is on for testing environments.
What I did to free up space is export the VM's to other storage repos. Deleted the extent and recreated a iscsi. The vm's totaled about 800GB, but the used space came in over 2TB.
This is the new space.
[root@sr001] /mnt/SR001/NFS/JennyTechnicalVM/79eb11a5-2f05-84c4-f090-da35dfe09e4f# zfs list -t all
NAME USED AVAIL REFER MOUNTPOINT
SR001 4.66T 2.36T 2.40G /mnt/SR001
SR001/.system 139M 2.36T 89.5M legacy
SR001/.system/configs-5ece5c906a8f4df886779fae5cade8a5 46.1M 2.36T 46.1M legacy
SR001/.system/cores 1.24M 2.36T 1.24M legacy
SR001/.system/rrd-5ece5c906a8f4df886779fae5cade8a5 192K 2.36T 192K legacy
SR001/.system/samba4 799K 2.36T 799K legacy
SR001/.system/syslog-5ece5c906a8f4df886779fae5cade8a5 1.34M 2.36T 1.34M legacy
SR001/FTP-Backups 554M 2.36T 554M /mnt/SR001/FTP-Backups
SR001/ISO 21.0G 2.36T 21.0G /mnt/SR001/ISO
SR001/cloudpbx 2.70T 2.36T 2.70T /mnt/SR001/cloudpbx
SR001/dev-vm 192K 2.36T 192K /mnt/SR001/dev-vm
SR001/jails 192K 2.36T 192K /mnt/SR001/jails
SR001/misc-vm 1.93T 2.36T 1.93T /mnt/SR001/misc-vm
SR001/sec-vm 1.49G 2.36T 1.49G /mnt/SR001/sec-vm
SR001/strata-temp 1.93G 2.36T 1.93G /mnt/SR001/strata-temp
freenas-boot 1.06G 27.0G 31K none
freenas-boot/ROOT 1.04G 27.0G 25K none
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201511280648 1.02G 27.0G 533M /
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201511280648@2015-11-10-04:02:18 2.49M - 510M -
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201511280648@2015-11-12-14:05:53 244K - 511M -
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201511280648@2015-11-29-13:44:34 10.4M - 520M -
freenas-boot/ROOT/Initial-Install 9.62M 27.0G 520M /
freenas-boot/ROOT/Wizard-2015-11-10_14:24:47 1K 27.0G 511M legacy
freenas-boot/ROOT/Wizard-2015-11-12_13:53:50 1K 27.0G 513M legacy
freenas-boot/ROOT/Wizard-2015-11-12_14:05:53 1K 27.0G 511M /
freenas-boot/ROOT/default 7.87M 27.0G 513M /
freenas-boot/ROOT/default@2015-11-10-14:24:47 245K - 511M -
freenas-boot/ROOT/default@2015-11-12-13:53:50 2.44M - 513M -
freenas-boot/grub 13.6M 27.0G 6.79M legacy
freenas-boot/grub@Pre-Upgrade-Wizard-2015-11-10_14:24:47 25.5K - 6.79M -
freenas-boot/grub@Pre-Upgrade-Wizard-2015-11-12_13:53:50 25.5K - 6.79M -
freenas-boot/grub@Pre-Upgrade-Wizard-2015-11-12_14:05:53 26K - 6.79M -
freenas-boot/grub@Pre-Upgrade-FreeNAS-9.3-STABLE-201511280648 26K - 6.79M -
The problem is still there with the other iscsi shares so I will repeat this process by moving vms and deleting the extent.
I am using Xenserver 6.5
XS65E001,XS65E002,XS65E003,XS65E005,XS65E006,XS65E007,XS65E008,XS65E009,XS65E010,XS65E013,XS65E014,XS65ESP1,XS65ESP1002,XS65ESP1003,XS65ESP1004,XS65ESP1008,XS65ESP1009,XS65ESP1010,XS65ESP1011,XS65ESP1012,XS65ESP1018 Patches loaded
