Freenas won't restart
alfred67
Hello
I'm running Freenas 8.2.0 release- p1-x86 and it was running great then one night there was a continuous beep so I restarted the system now I get an error , It says" Enter full pathname or return for /bin/sh:" ( see attached image)
I'm not sure what to do now. I tried to update to 9.2.1.3 (32 bit) but it will not allow me to mount my drive
Any help would be great.
Thanks
Alfred67
alfred67
Ok, I will give that a try .
Is there anyway to get my config file from the usb stick??
D
dlavigne
Guest
Not easily. Right now your issue is with the filesystem on your data disk. Hopefully fsck can sort it.
alfred67
It worked Run fsck -y and it up and running with all my data --Thank you very much dlavigne
Should I upgrade from 8.2 to 9.2??
