I am new to FreeNas and am currently running 8.2.0-release-p1 x86. Setup with UFS. With the FreeNAS-8.2.0-RELEASE-x86.Plugins_Jail.pbi installed.
I am currently using the Jail Plugins service to create a jail. This works fine, i have various apps installed in the Jail, setup as services which start when the jail starts etc etc. My issue is with the shutdown. From the jail i can run the rc.shutdown and all the services shutdown properly. I need this to run when the plugin service is stopped from the webGUI or the system is shutdown.
I have noticed that on the NAS the various jail settings within rc.conf are not added until the plugin service is started from the webGUI. I have also noticed that any additional settings i place in the rc.conf file are removed if they are a "jail" setting.
For example if i add the following:
jail_<jailname>_exec_stop="/bin/sh /etc/rc.shutdown"
it will be removed when the plugin service is started. If the setting i add is not related to a jail it remains.
Is there a way that I can add a custom "jail" setting? Perhaps there is a reason for this?
Is there a better way to get the shutdown to work?
I'm sure that individual pbi's could be created for each application i have installed, but for testing i would like to get this working.
Thanks
Mike
Thanks
Mike
