FreeNAS-8.3.1-ALPHA-r12516M-x86.iso
meho
Hello Everyone,
I was just wondering, when i downloaded the FreeNAS-8.2.0-RELEASE-p1-x86.iso image, the size was 96M.
I installed the 8.2.0 release and tried it out, I like it. However, curiosity did get the better of me, so I wanted to compile and install a fresh installation.
I updated my sources and checked out the FreeNAS. After following the instructions in the README, I ended up with the fresh ISO and images. My question is,
Why is the image I compile on my machine twice the size than the ISO i downloaded?
[19:48] root@disgrace [/usr/src/trunk/os-base/i386] # uname -a ; ls -alh | egrep '(Free|*.img)' ; ls -alh /saved/FreeNAS-8.2.0-RELEASE-p1-x86.iso
FreeBSD disgrace 9.0-RELEASE-p3 FreeBSD 9.0-RELEASE-p3 #2 r237939: Thu Jul  5 20:00:25 EDT 2012     root@disgrace:/usr/obj/opt/src/sys/disgrace  i386
-rw-r--r--   1 root  wheel   164M Oct  1 17:15 FreeNAS-8.3.1-ALPHA-r12516M-x86.GUI_Upgrade.txz
-rw-r--r--   1 root  wheel   149M Oct  1 16:53 FreeNAS-8.3.1-ALPHA-r12516M-x86.GUI_Upgrade.xz
-rw-r--r--   2 root  wheel   149M Oct  1 08:20 FreeNAS-8.3.1-ALPHA-r12516M-x86.img.xz
-rw-r--r--   1 root  wheel   219M Oct  2 02:18 FreeNAS-8.3.1-ALPHA-r12516M-x86.iso
-rw-r--r--   1 root  wheel   157M Oct  2 14:53 _.imgfile
-rw-r--r--   1 root  wheel   942M Oct  1 08:21 firmware.img
-rw-r--r--  1 brenda  brenda    96M Sep 25 16:05 /saved/FreeNAS-8.2.0-RELEASE-p1-x86.iso
Also, as we can see from uname -a, I compiled this on a 9.0-RELEASE. Is this a problem?
It Seems when I attempt to boot this installation image in virtualbox, it hangs right after it loads the kernel and never boots.
I know the README says the environment need to be 8.2 or higher so I am wondering if 9.0 was the problem :)
thanks in advance.
William Grzybowski
ALPHA images are debug images, for developers, they have more packages compiled in, thats why they are bigger.
meho
ok, I see, I would have liked the BETA version but this (ALPHA) is what svn pulled, either way, it doesn't matter.
my next question:
what kernel config file does one edit?
is it:
/usr/src/trunk/FreeBSD/src/sys/i386/conf/GENERIC
or
/usr/src/sys/i386/conf/GENERIC
also, this is a screenshot of where it hangs on boot in VirtualBox.
I thought that, since the ISO was so large, it would have taken a while to decompress (It took 9 hours for xz to compress the image during the build).
I was wondering if it was in fact possible to compile on 9.0-RELEASE, I assume it was ok as the build completed without any errors.
I'm stumped
William Grzybowski
The kernel config to edit is nanobsd/FREENAS.i386
No idea why it is hanging on boot for you, works for me. And yes, you can use 9.0 to build.
meho
Thank you so much for your input.
Ok, I will try to work through this and post back the results if there are any.
meho
ok, I disabled the debug and recompiled. all seems well for now
Host:
running VirtualBox
FreeNAS guest:
FreeBSD freenas 8.3-RELEASE-p4 FreeBSD 8.3-RELEASE-p4 #1 r241076M: Wed Oct  3 13:37:53 EDT 2012     root@disgrace:/usr/src/trunk/os-base/i386/opt/src/trunk/FreeBSD/src/sys/FREENAS.i386  i386
of coarse, compile time with debug off was a fraction of the time but that too may have some consequences.
