Hello Everyone,
I was just wondering, when i downloaded the FreeNAS-8.2.0-RELEASE-p1-x86.iso image, the size was 96M.
I installed the 8.2.0 release and tried it out, I like it. However, curiosity did get the better of me, so I wanted to compile and install a fresh installation.
I updated my sources and checked out the FreeNAS. After following the instructions in the README, I ended up with the fresh ISO and images. My question is,
Why is the image I compile on my machine twice the size than the ISO i downloaded?
Also, as we can see from uname -a, I compiled this on a 9.0-RELEASE. Is this a problem?
It Seems when I attempt to boot this installation image in virtualbox, it hangs right after it loads the kernel and never boots.
I know the README says the environment need to be 8.2 or higher so I am wondering if 9.0 was the problem :)
thanks in advance.
[19:48] root@disgrace [/usr/src/trunk/os-base/i386] # uname -a ; ls -alh | egrep '(Free|*.img)' ; ls -alh /saved/FreeNAS-8.2.0-RELEASE-p1-x86.iso FreeBSD disgrace 9.0-RELEASE-p3 FreeBSD 9.0-RELEASE-p3 #2 r237939: Thu Jul 5 20:00:25 EDT 2012 root@disgrace:/usr/obj/opt/src/sys/disgrace i386 -rw-r--r-- 1 root wheel 164M Oct 1 17:15 FreeNAS-8.3.1-ALPHA-r12516M-x86.GUI_Upgrade.txz -rw-r--r-- 1 root wheel 149M Oct 1 16:53 FreeNAS-8.3.1-ALPHA-r12516M-x86.GUI_Upgrade.xz -rw-r--r-- 2 root wheel 149M Oct 1 08:20 FreeNAS-8.3.1-ALPHA-r12516M-x86.img.xz -rw-r--r-- 1 root wheel 219M Oct 2 02:18 FreeNAS-8.3.1-ALPHA-r12516M-x86.iso -rw-r--r-- 1 root wheel 157M Oct 2 14:53 _.imgfile -rw-r--r-- 1 root wheel 942M Oct 1 08:21 firmware.img -rw-r--r-- 1 brenda brenda 96M Sep 25 16:05 /saved/FreeNAS-8.2.0-RELEASE-p1-x86.iso
thanks in advance.
