########## ZPool status report summary for all pools ########## +--------------+--------+------+------+------+----+--------+------+-----+ |Pool Name |Status |Read |Write |Cksum |Used|Scrub |Scrub |Last | | | |Errors|Errors|Errors| |Repaired|Errors|Scrub| | | | | | | |Bytes | |Age | +--------------+--------+------+------+------+----+--------+------+-----+ |freenas-boot |ONLINE | 0| 0| 0| 25%| 0| 0| 2| |Storage !|ONLINE | 0| 0| 0| 91%| 0| 0| 7| |Working ?|ONLINE | 0| 0| 0| 82%| N/A| N/A| N/A| +--------------+--------+------+------+------+----+--------+------+-----+ ########## ZPool status report for freenas-boot ########## pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:01:10 with 0 errors on Fri Jun 29 03:46:10 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 ada2p2 ONLINE 0 0 0 errors: No known data errors ########## ZPool status report for Storage ########## pool: Storage state: ONLINE scan: scrub repaired 0 in 0 days 10:49:28 with 0 errors on Sun Jun 24 10:50:29 2018 config: NAME STATE READ WRITE CKSUM Storage ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/c82e64d9-08c8-11e6-af21-002590d51bcc ONLINE 0 0 0 gptid/c900ab50-08c8-11e6-af21-002590d51bcc ONLINE 0 0 0 gptid/c9ce79d8-08c8-11e6-af21-002590d51bcc ONLINE 0 0 0 gptid/ca8cde35-08c8-11e6-af21-002590d51bcc ONLINE 0 0 0 gptid/cb518bbb-08c8-11e6-af21-002590d51bcc ONLINE 0 0 0 gptid/cc0ff7c7-08c8-11e6-af21-002590d51bcc ONLINE 0 0 0 errors: No known data errors ########## ZPool status report for Working ########## pool: Working state: ONLINE scan: resilvered 4K in 0 days 00:00:00 with 0 errors on Sat Jun 30 21:11:04 2018 config: NAME STATE READ WRITE CKSUM Working ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/c017dfa0-3db1-11e8-8175-002590d51bcc ONLINE 0 0 0 gptid/230564fa-7882-11e8-b523-002590d51bcc ONLINE 0 0 0 gptid/5a407b9e-2d3f-11e7-a1b5-002590d51bcc ONLINE 0 0 0 gptid/5b09f1bc-2d3f-11e7-a1b5-002590d51bcc ONLINE 0 0 0 errors: No known data errors
Last login: Sun Jul 1 12:06:56 2018 from 192.168.1.100 FreeBSD 11.1-STABLE (FreeNAS.amd64) #0 r321665+e0c4ca60dfc(freenas/11.1-stable): Wed EDT 2018 FreeNAS (c) 2009-2017, The FreeNAS Development Team All rights reserved. FreeNAS is released under the modified BSD license. For more information, documentation, help or support, go here: http://freenas.org Welcome to FreeNAS Warning: settings changed through the CLI are not written to the configuration database and will be reset on reboot. root@freenas:~ # smartctl -a /dev/ada1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD80EZAZ-11TDBA0 Serial Number: 1SGMVWBZ LU WWN Device Id: 5 000cca 26bc907f7 Firmware Version: 83.H0A83 User Capacity: 8,001,563,222,016 bytes [8.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Sun Jul 1 12:09:27 2018 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 93) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 972) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0004 129 129 054 Old_age Offline - 112 3 Spin_Up_Time 0x0007 146 146 024 Pre-fail Always - 451 (Average 453) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 21 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000a 100 100 067 Old_age Always - 0 8 Seek_Time_Performance 0x0004 128 128 020 Old_age Offline - 18 9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 2080 10 Spin_Retry_Count 0x0012 100 100 060 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 21 22 Unknown_Attribute 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 130 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 130 194 Temperature_Celsius 0x0002 196 196 000 Old_age Always - 33 (Min/Max 15/51) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 2069 - # 2 Short offline Completed without error 00% 2045 - # 3 Short offline Completed without error 00% 2022 - # 4 Short offline Completed without error 00% 1998 - # 5 Extended offline Completed without error 00% 1990 - # 6 Short offline Completed without error 00% 1974 - # 7 Short offline Completed without error 00% 1950 - # 8 Short offline Completed without error 00% 1926 - # 9 Short offline Completed without error 00% 1926 - #10 Short offline Completed without error 00% 1902 - #11 Short offline Completed without error 00% 1902 - #12 Short offline Completed without error 00% 1878 - #13 Short offline Completed without error 00% 1854 - #14 Short offline Completed without error 00% 1854 - #15 Short offline Completed without error 00% 1830 - #16 Short offline Completed without error 00% 1830 - #17 Extended offline Completed without error 00% 1822 - #18 Short offline Completed without error 00% 1806 - #19 Short offline Completed without error 00% 1806 - #20 Short offline Completed without error 00% 1782 - #21 Short offline Completed without error 00% 1758 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. root@freenas:~ #
