Freenas not accessing internet
Mickey B
Hi all,
I have been struggling along with Plex for a while, and i have been using the mstinaff updater from github process for a while now, but recently it stopped working.
I have also recently had my ISP taken over and i now have a new ISP. Fair to say that the router IP address info has changed somewhat.
When i noticed that Plex stopped working, i tried to check to see if there were updates to Freenas that i hadnt downloaded/installed yet. Unfortunately, it would error out and there would be no updates. I hadnt seen that before, so i have been mucking around with general network settings when i noticed that the nameservers (after going back to Festers install guide) are supposed to be Primary and Secondary DNS servers (which had changed). So i updated to new ones as per router info and then i got a load of updates, which i installed.
This didnt fix the problem though. I still couldnt access plex servers. So i attempted the PMS_updater.sh process again and when in shell, it just hangs. Nothing happens.
I am quite sure that there is now an issue between my router setup as i had it since install, and the new settings from the new ISP.
I check the router page and noticed that default gateway has changed, and on my LAN TCP/IP setup page, it still has the IP at 192.168.1.1 and the range as previously stipulated 192.168.1.26 through to 200.
I suspect that Freenas cant access internet as 192.168.1.1 is no longer the default gateway, and i cant change it on Freenas, because it fails, which i suspect is due to the new default gateway not being within the range of the DCHP.
Is there some info that i could provide that might shed some light on my dramas?
Terribly sorry for wall of text, but i wanted to give as much info as i could to show what i was up to so far in my thinking.
Thanks in advance :)
Just a few questions to make sure I understand. The more precise and clear the better :)
This sounds like you were able to connect to the web after updating the DNS servers because you were able to download the updates?
What is it now?
I imagine you're referring to your FreeNAS machine and that it is set to 192.168.1.1?
I suspect that Freenas can't access internet as 192.168.1.1 is no longer the default gateway, and i can't change it on Freenas, because it fails, which i suspect is due to the new default gateway not being within the range of the DCHP.
How exactly does it fail? Do you get an error message? Does it hang? I assume you're trying to update it in the UI?
I'm not entirely clear on your setup. If you changed ISPs your external IP likely changed. Do you have anything that depends on your external IP?
Mickey B
Hi Philo,
Thanks for pointing that out. I did download the updates after i added the correct DNS servers.
The default gateway listed on the router is now 116.255.11.1
These are global network settings in freenas (i dont know how to change the interface to the new one sorry)
The error i received was from shell when trying to update UMS_Updater.sh from github
Regarding devices that depend on ip, i have PS4, PS3, Yamaha AMP, Xbox and all seem to operate through the original default gateway of 192.168.1.1.
This is the router settings in the LAN TCP/IP page - i think i may need to change these to reflect the new ISP settings, but with everything bar PLEX working, i am loathe to fiddle.
I havent changed these since the new ISP changeover. Below are the Yamaha network settings
I havent changed these on the Yamaha AMP, and the Yamaha app finds and play mp3 from the plexmediaserver_1 Music Jail quite well.
Only recently was plex not showing in browser. Which has led me down this very confusing path.
I have spent a few nights til very late trying to find out where ive gone wrong. More than happy to continue, but i short of deleting and starting over, i am stumped as to why some things are working and why some are not.
Thank you for replying
Can any other device connect to the internet via your router? If so, I suspect that the issue is not related to your router being unable to talk to your modem and ISP.
What happens if you ping a website from your FreeNAS box? Do you get any packets back?
You could also change your router's staring IP address to 192.168.1.2 to give you the full range. I notice that both Yamaha and FreeNAS both are assigned addresses < 26, which is where your router is set to start IP address from.
Mickey B
The router and all devices are functioning as normal, i seems to be only that i cant access plex server in browser and i cant update it via shell. I had been getting updates in Freenas such as the January one, but when ISP changed, the Feb update couldnt be reached until the DNS were changed. Ive looked up the error in shell, and it suggests a DNS lookup issue.
I dont know how to ping a website from the Freenas. Does that happen in shell?
I think it was Fester's guide that said to lockout some local IP address to permamently assign to devices, and then start DCHP from 26 so that the router would only assign IP to new devices from that point on.
All has been working perfectly until either the update, or the ISP change and now i think i am coming to terms with (slowly maybe) that there might be a mismatch in Freenas box settings somewhere. It is a custom build and it took too long to mention as a noob, so i really am playing with fire.
The wierd thing is that locally, devices can access plex, but through browser it cant. That suggests it might be over my head.
I don't know how to ping a website from the Freenas. Does that happen in shell?
Yes, you can run something like ping -c 1 www.google.com.
Ah interesting. My router doesn't assign anything an IP which is reserved.
The wierd thing is that locally, devices can access plex, but through browser it can't. That suggests it might be over my head.
What exactly do you mean by locally devices can access plex? I assume you mean a laptop or some other device you have? And when you say, "access plex" are you referring to the plex server on your FreeNAS box? And when you say, "though browser it can't" what do you mean? What can't? Which browser?
I'll be honest, I'm at somewhat of a loss. It is a bit difficult to understand your exact setup though. It would help greatly if you posted exactly what machines and devices you have, what router, which mode, and how your different devices and machines connect to the router, mode, or one another. It is difficult to offer specific advice not knowing exactly how your home network is set up and exactly what you're trying to do. Posting screen shots of errors or exact commands you ran would certainly be helpful.
I am hesitant to offer any other suggestions because I don't know enough about your network etc. Here is an example of what I mean by describing your network. As an example my network consists of . . .
1 Modem
1 Router which connects to my modem
1 FreeNAS machine hard-wired into my router
1 Instance of RancherOS running on this FreeNAS machine
1 Backup FreeNAS machine hard-wired into my router
3 Laptops connected to my router via WIFI
Various phones connected to my router via WIFI
All of my laptops, both FreeNAS machines, and RancherOS have static local IP addresses.
Mickey B
May i ask how you add "Mickey B said" to your replies?
I will compile a snapshot of the network, devices and settings and show it all. I admit, i believe it to be a complex and probably subtle issue, but i agree that without such info it is near impossible. I'm off to work now, but ill get it on here tonight, approx 12 hours from now.
Thanks so far friend :)
Highlight the text you want to reply to, then click the "Reply" button that appears below it:
Mickey B
Both the laptop and the LG tv and the Yamaha are LAN connected automatic with no adjustment to settings. The PS4's media server, Yamaha and LGTV can access the PLEX server found on the local network and work just fine.
The browser on the laptop and my phone (remotely) have previously been able to access the server but cant any longer.
Settings for router are as a snapshot
and in more detail
Then the LAN settings page where i have reserved specific address for PS4, Freenas and Yamaha
this is the connected devices
These are the global network settings on freenas
This is the jail settings for PLEX
So after discovering that i can access PLEX on my local network, it must be that i am unable to access via internet which is what i would be doing on my laptop browser and my phone browser.
But...which setting affects outgoing traffic?? And is this even the right question?
Anyway - i am getting close to just doing without until i upgrade to 11.2.1 or whatever it is and maybe ill get the cool new interface!
Please let me know what you think and thank you for your time thus far.
Mickey B
By the way, this worked great thank you
[root@freenas ~]# ping -c 1 www.google.com
PING www.google.com (216.58.199.68): 56 data bytes
64 bytes from 216.58.199.68: icmp_seq=0 ttl=55 time=19.724 ms
--- www.google.com ping statistics ---
1 packets transmitted, 1 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 19.724/19.724/19.724/0.000 ms
[root@freenas ~]#
@Mickey B thanks for the detailed info, that helps a lot.
The browser on the laptop and my phone (remotely) have previously been able to access the server but can't any longer.
To be clear, do you mean that your laptop and phone cannot reach your local plex server from outside of your network (such as while at work)? Or do you mean that they can't access your local plex server even from within your home network? If they work from within your network but not from outside of your network your issue may be that you have to expose your plex server to the outside web.
Did you change any of the plex network settings? For example, prior to things breaking did your Plex server have a subnet mask set or NIC selected?
Also, FWIW, you may consider obscuring your external IP address. That way folks won't have your IP address and your local network topology in case they wanted to do something nefarious.
Which version are you currently running? I'm not sure if upgrading to 11.2 will help your problem or perhaps add a few on top of it.
Sorry I'm not able to immediately spot your problem. :/ I was hoping it'd be something simple and obvious to me. Maybe we will get lucky and something will pop out or someone more knowledgable will chime in with the solution. :)
Your plex server will never get out with a blank default gateway... you need to set that to your router IP and it will probably start working right away (after a restart perhaps).
Mickey B
Both work and home. When i open a browser on my laptop or my phone and direct it to the plex login page, i login and then it will continue to search for, and never find my PLEX server. This happens within the network, and remotely. This i find odd as my devices still access PLEX within the network, just not through browser.
Is this option set from the Freenas box or with the account? I remember accessing server settings from within a browser, but i cant get to that screen now. Most of my search has included tutorials that discuss settings from Plex server, but i cant get there to change anything.
I knew there was something that is usually withheld, but i couldnt remember which. It doesnt matter anyway atm as i think the router has something different now anyway. I think it keeps changing on the router. If you think i may have the wrong of it, please tell me and ill delete or modify.
Im running 11.1 U7 - i may just keep away for now until i isolate my current issue.
Many thanks indeed. I hate asking for help. I am usually stubborn and will search until my eyes bleed but i just am not finding anything that fits my exact problem, so i appreciate how helpful you have been so far :)
In a nutshell, my ISP changed, and so did my DNS servers, which meant that Freenas couldnt access internet to check for updates. I didnt know this was a problem at first, i just noticed that i couldnt access PLEX media server remotely. I followed my usual check-for-updates-on-everything pattern
and discovered the DNS thing. I updated the DNS in general network settings and then checked for updates. When the updates came down and installed, i thought that might have fixed it, but still was an issue. Devices (yamaha, ps4, lgtv) were still accessing PMS, but when in remote browser, the server was never found.
I have read about DNS rebinding, but i dont understand it well, or even if it applies to me. I suspect that there is some sort of disconnect between the jail, and plex external. Like it cant dial out or something. Ill keep plugging away, and checking back here for solutions.
This would be amazing. As i said, i hate asking for help, but i am hoping someone spots something i have overlooked or forgotten about that is the missing link in my understanding.
Mickey B
In the Jail? I noticed that there were a lot of blanks, but i havent changed these settings since install so i thought best not to touch it. Ill give it a try and report back.
Because your FreeNAS box has access to the internet @sretalla's suggestion would certainly be my next guess.
Mickey B
I can access interal, but i cant access external this is right. How can i 'expose' Plex to the outside web. Remember, i didnt actually change anything except for the ISP and settings on router.
The Jail had a subnet of 255.255.255.0 for IPv4, but no NIC selected. Also DCHP is off.
I was reading this found on Reddit and it led to this page and it made me think that i need to SSH into the jail, but when i follow those instructions, i dont get the responses from shell that the instructions shows.
I also discovered i can access the new interface by adding /ui to my Freenas IP address and i noticed that none of the Jails and Plugins are there, and in the storage section it shows the jails are as IOCAGE jails. I followed Uncle Fester's setup when first installing, and i have never upgraded to IOCAGE jails. I also seem to get a host of errors that might be related to my problem.
I have to say, that while functionality is near normal, i am troubled by not being able to access PLEX remotely as well as the absence of jails and plugins in the new interface.
Does this mean the default gateway on the router? I changed it to the default gateway listed on the internet setup page and i changed it to the usual default gateway and i got this in the green writing
Any further thoughts?
Mickey B
I also just saw this in the new UI
It shows, old jails AND iocage jails. I have no idea how this might contribute to the problem
