Ak2WQVVWcI7YzcLqDJGid
- Apr 18, 2019
Purchased a FreeNAS Mini XL about 3 years ago. 2 days ago I woke up to numerous email alerts about unscheduled reboots. I was unable to reach the webui remotely so I connected a monitor and briefly saw a message about a kernel panic. The system was completely unresponsive so I powered cycled it and it appears to power on but I have no output from the VGA port.
IPMI works and it shows everything as healthy but nothing else seems to work. The NIC lights up when I plug in an ethernet cable but I have no response from the static IP.
Not sure where to go from here. I would assume I would have some sort of output from the mobo even if the boot drive died.
Where should I begin troubleshooting this?
Final email alert I received.
FreeNAS @ freenas.lan
The following alert has been cleared:
* Device: /dev/ada7, Self-Test Log error count increased from 0 to 1.
Current alerts:
* freenas.lan had an unscheduled system reboot.
The operating system successfully came back online at Fri Aug 7 18:17:01 2020.
* Scrub of pool 'Pool1' started.
* Scrub of pool 'Pool1' finished.
* Scrub of pool 'freenas-boot' finished.
The operating system successfully came back online at Sun Aug 30 17:15:25 2020.
The operating system successfully came back online at Sun Aug 30 17:32:10 2020.
The operating system successfully came back online at Sun Aug 30 18:03:17 2020.
The operating system successfully came back online at Sun Aug 30 18:17:06 2020.
The operating system successfully came back online at Sun Aug 30 18:33:22 2020.
The operating system successfully came back online at Sun Aug 30 18:59:43 2020.
The operating system successfully came back online at Sun Aug 30 19:13:59 2020.
The operating system successfully came back online at Sun Aug 30 19:22:59 2020.
The operating system successfully came back online at Sun Aug 30 19:32:38 2020.
The operating system successfully came back online at Sun Aug 30 19:44:58 2020.
The operating system successfully came back online at Sun Aug 30 19:55:30 2020.
The operating system successfully came back online at Sun Aug 30 20:03:57 2020.
The operating system successfully came back online at Sun Aug 30 20:13:26 2020.
The operating system successfully came back online at Sun Aug 30 20:21:41 2020.
The operating system successfully came back online at Sun Aug 30 20:38:48 2020.
The operating system successfully came back online at Sun Aug 30 20:47:27 2020.
The operating system successfully came back online at Sun Aug 30 20:56:28 2020.
The operating system successfully came back online at Sun Aug 30 21:03:57 2020.
The operating system successfully came back online at Sun Aug 30 21:14:14 2020.
The operating system successfully came back online at Sun Aug 30 21:20:59 2020.
The operating system successfully came back online at Sun Aug 30 21:29:29 2020.
The operating system successfully came back online at Sun Aug 30 21:36:53 2020.
The operating system successfully came back online at Sun Aug 30 21:43:46 2020.
The operating system successfully came back online at Sun Aug 30 21:49:48 2020.
The operating system successfully came back online at Sun Aug 30 21:57:00 2020.
The operating system successfully came back online at Sun Aug 30 22:04:58 2020.
The operating system successfully came back online at Sun Aug 30 22:12:30 2020.
The operating system successfully came back online at Sun Aug 30 22:22:20 2020.
The operating system successfully came back online at Sun Aug 30 22:31:03 2020.
The operating system successfully came back online at Sun Aug 30 22:41:19 2020.
The operating system successfully came back online at Sun Aug 30 22:49:37 2020.
The operating system successfully came back online at Sun Aug 30 22:57:34 2020.
The operating system successfully came back online at Sun Aug 30 23:04:41 2020.
The operating system successfully came back online at Sun Aug 30 23:15:28 2020.
The operating system successfully came back online at Sun Aug 30 23:23:19 2020.
The operating system successfully came back online at Sun Aug 30 23:30:44 2020.
The operating system successfully came back online at Sun Aug 30 23:41:18 2020.
The operating system successfully came back online at Sun Aug 30 23:48:14 2020.
The operating system successfully came back online at Sun Aug 30 23:55:29 2020.
The operating system successfully came back online at Mon Aug 31 00:03:02 2020.
The operating system successfully came back online at Mon Aug 31 00:10:21 2020.
* A system update is available. Go to System -> Update to download and apply the update.
* Device: /dev/ada5, 1 Currently unreadable (pending) sectors.
Current alerts:
