freenas.local smartd 1114 - - Device: /dev/da1 [SAT], 8 Currently unreadable (pending) sectors
cozd74
problem: for some time I get this error message on my FreeNAS (TrueNAS-12.0-U7)
dev/da1 is a 1TB external USB drive used by a Plex library
Proposed solution: http://bytesandbolts.com/fixing-freenas-error-currently-unreadable-pending-sectors/
I applied the proposed solution to my problem: attached the outcome of the checks of my disk
dd if=/dev/zero of=/dev/da1 bs=4096 count=8 seek=190056456
I tried to run the following command by setting bs=512 and then also to 4096 but the problem remains
how can I do?
thanks
  • freenas.fritz.box-dev_da1.txt
NugentS
Take the drive out and plug it into a real port.
Then erase the drive in some manner, making sure you write to every sector at which point the drive should reallocate the dead sectors
Wether the drive is still good is an answer you should consider carefully - throw every test you can think of at the drive
