Freenas keep rebooting
arim215
My freenas system keeps rebooting...(view system reporting)... i have the logs but can't see anything...
http://i58.tinypic.com/wgw5rl.jpg
in what file can i find the info needed to resolve this probleme? ready to post the debug files...
pirateghost
Unintelligible Geek
I see you making lots of posts but I don't see your hardware specs per the forum rules. Every problem I see you having are indicative of improper hardware.
FreeNAS version, hardware...?
arim215
Sorry! I didn't know
FreeNAS-9.3-STABLE-201412142326
Hardware:
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Asus P5W DH Deluxe mobo
8GB of Kingston RAM
1 WD Green 1TB
1 WD 250GB
2 Seagate 250GB
2GB ATA DOM disk (freenas boot disk)
enemy85
@arim215 am I reading wrong or do you use a 2gb dom disk for boot disk? maybe is that the problem
arim215
I double checked and its an 8gb KingSpec Dom Disk. been using it since frenas 7.x and havent had any trouble with it...
arim215
i just looked (to double check my hardware) and everything looks good... no dust on heatsink, no blown caps, cables well plugged... im checking if it might be my onboard NIC, i switched to an other one to see if i get issues... might solve both of my problems.
arim215
i keep getting this email
The volume Backups (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
The volume Shares (ZFS) state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
Backups has a bad disk but nothing has been lost yet (redundancy FTW!).
Shares did not have sufficient redundancy to correct the errors and data has been lost.
So what you likely have is a pool that is corrupt and it is causing the system to kernel panic when ZFS get corrupted. Box reboots and runs again until you hit the corruption. The bam, reboot again.
Single disk zpools are "of the devil" and shouldn't be used. You're an unwilling example of why this is so.
In any case, you have at least 2 bad disks in your server and you should stop and assess your original design and correct these limitations before continuing to use the server, and definitely before you store your precious data on it because you are already losing data on Shares.
arim215
how should i create my pool if i plan on expanding it, but only have 1 drive now? should i make a normal drive (Not ZFS) and when i get an expansion, i transfer data and add this one to the new drive?
pirateghost
Unintelligible Geek
You can't do this.
