FreeNAS FTP / SMB share
shuffman
I'm new to FreeNAS and running 9.10 with all updates. I have a share called backups and can see and edit it from Windows with no problems. I also have a FreePBX CentOS 6.5 system that I have setup to do FTP backups to the FreeNAS same share as Windows and both work, my problem is if I do a backup to the FTP from my centos it backups fine but I can't see it from Windows, but if I FTP from windows to it then I see the files in the same directory as the Windows share and can delete and so on. How can I get it so FTP and Windows share view both ways?
snaptec
Please reread your Post.
Should there be a "cant"?
Or is it just too Late and i dont get it
Gesendet von iPhone mit Tapatalk
melloa
Trying to understand the problem... You are saying:
- You have created a SMB share in FreeNAS
- You have full access to it from windows
- You are using ftp to ftp files from a linux box to it and it's working
- You can't see the files you have copied from the linux box via ftp
(?'s)
- Is the above correct?
- Assume you are mounting the FreeNAS share in your linux box
- Can you see and manipulate the files from the linux box?
- Have you created more than one directory inside the FreeNAS SMB share?
- Do your windows user have the same access to all?
As you can see lots of questions. Perhaps you can break down and provide more information, otherwise people won't be able to help.
shuffman
(?'s)
All is correct!
I have created a share called backup on the FreeNAS
It has SMB and FTP enabled to the backup share.
From a Windows PC I can see the share and add and remove files from it.
From my Linux Centos I have it doing backups to the FTP backup folder and it works
When I FTP to the freeNAS backup folder I can see the backup directory and all the FTP files in it but none of the Windows files.
When I use my Windows pc explorer and browse to the backup folder I see all the Windows files but none of the FTP files.
I'm using the same user account for both systems and both systems see directories but no files.
I have also changed to rights to the ftp files to 777 and still cant see them, I have also told the SMB share to show hidden files.
This is a new load and only one account created besides the root.
melloa
Probably not coffee enough here, but I just got a question: Why are you using ftp to copy files from linux to a SMB share?
shuffman
I'm using FTP from the Linux to do backups as the FreePBX system supports, the SMB is so I can get to the backups from a Windows explorer to view and copy off for offsite.
pirateghost
Unintelligible Geek
Pretty sure that unless your ftp user account's home directory is the backup directory, then what you are actually seeing is 2 different directories.
shuffman
I thought the same thing but I can create a directory with Windows and see it in the FTP and versa just not files.
shuffman
I take that back I just tried that again and it isn't showing the same, so with that how can I get it to?
shuffman
Never mind I figured it out by setting the users home directory as the same as the Windows Share it fixed it. Thanks everyone for the help!
melloa
Glad you got it.
