Try with a "cat" before...
1gb RAM is more than unsupported. That will cause strange problems!
Gesendet von iPhone mit Tapatalk
cat /var/log/messages
Jan 2 02:15:59 freenas proftpd[7459]: 127.0.0.1 (192.168.1.3[192.168.1.3]) - USER anonymous: no such user found from 192.168.1.3 [1
92.168.1.3] to ::ffff:192.168.1.100:21
Jan 2 02:16:03 freenas proftpd[7460]: 127.0.0.1 (192.168.1.3[192.168.1.3]) - USER aizul: no such user found from 192.168.1.3 [192.1
Jan 2 02:16:06 freenas proftpd[7461]: 127.0.0.1 (192.168.1.3[192.168.1.3]) - USER aizul: no such user found from 192.168.1.3 [192.1
Jan 2 02:18:34 freenas notifier: Stopping proftpd.
Jan 2 02:18:35 freenas proftpd[1887]: 127.0.0.1 - ProFTPD killed (signal 15)
Jan 2 02:18:35 freenas proftpd[1887]: 127.0.0.1 - ProFTPD 1.3.5a standalone mode SHUTDOWN
Jan 2 02:18:35 freenas notifier: Waiting for PIDS: 1887.
Jan 2 02:18:35 freenas notifier: Starting proftpd.
Jan 2 02:18:35 freenas notifier: 2007-01-02 02:18:35,211 freenas.local proftpd[7873] 127.0.0.1: 127.0.0.1:21 masquerading as 192.16
8.1.100
Jan 2 02:18:35 freenas proftpd[7874]: 127.0.0.1 - ProFTPD 1.3.5a (maint) (built Wed Jan 11 2017 17:22:21 UTC) standalone mode START
UP
Jan 2 02:18:40 freenas proftpd[7876]: 127.0.0.1 (192.168.1.3[192.168.1.3]) - USER anonymous: no such user found from 192.168.1.3 [1
Jan 2 02:18:44 freenas proftpd[7877]: 127.0.0.1 (192.168.1.3[192.168.1.3]) - USER aizul: no such user found from 192.168.1.3 [192.1
Jan 2 02:18:52 freenas proftpd[7889]: 127.0.0.1 (192.168.1.3[192.168.1.3]) - USER faris: no such user found from 192.168.1.3 [192.1
cat /var/log/auth.log
[root@freenas ~]# cat /var/log/auth.log
Jan 29 13:03:13 freenas shutdown: reboot by root:
Jan 1 10:04:18 freenas shutdown: reboot by root:
Jan 1 09:46:18 freenas login: 2 LOGIN FAILURES ON pts/1
Jan 1 09:46:18 freenas login: 2 LOGIN FAILURES ON pts/1, skor2016
Jan 1 09:46:23 freenas login: pam_acct_mgmt(): authentication error
Jan 1 09:47:41 freenas login: 2 LOGIN FAILURES ON pts/1
Jan 1 09:47:41 freenas login: 2 LOGIN FAILURES ON pts/1, root
Jan 1 09:48:18 freenas login: pam_acct_mgmt(): authentication error
Jan 1 09:48:23 freenas login: 2 LOGIN FAILURES ON pts/0
Jan 1 09:48:23 freenas login: 2 LOGIN FAILURES ON pts/0, root
Jan 1 09:48:41 freenas login: 2 LOGIN FAILURES ON pts/0
Jan 1 09:48:41 freenas login: 2 LOGIN FAILURES ON pts/0, aizul
Jan 1 09:48:46 freenas login: pam_acct_mgmt(): authentication error
Jan 1 09:49:56 freenas login: 1 LOGIN FAILURE ON pts/0
Jan 1 09:49:56 freenas login: 1 LOGIN FAILURE ON pts/0, root
just to inform.. my
freenas ip : 192.168.1.100
laptop ip : 192.168.1.3
i dont understand why he search user inside my laptop not in freenas
and i cant do anything about spec until this project really work. so i cant propose for upgrading
