FreeNAS freezes…
Youri Andropov
Hello all,
I'm using plex media server (PMS) in a freenas jail, and I have some problems, which I believe more related to freenas than to plex.
The problem is that the plex web GUI may be unresponsive, some requests get no answer.
To illustrate my problem, I logged on freenas, and pinged the PMS jail :
$ while :; do date; ping -c 1 -t 60 192.168.0.101 > /dev/null; sleep 1; done
with such a result :
Wed Sep 3 20:40:01 CEST 2014
Wed Sep 3 20:40:02 CEST 2014
Wed Sep 3 20:40:03 CEST 2014
Wed Sep 3 20:40:04 CEST 2014
Wed Sep 3 20:40:05 CEST 2014
Wed Sep 3 20:40:06 CEST 2014
Wed Sep 3 20:40:18 CEST 2014
Wed Sep 3 20:40:30 CEST 2014
Wed Sep 3 20:40:42 CEST 2014
Wed Sep 3 20:40:43 CEST 2014
Wed Sep 3 20:40:44 CEST 2014
Wed Sep 3 20:40:45 CEST 2014
Wed Sep 3 20:40:46 CEST 2014
Wed Sep 3 20:40:47 CEST 2014
As you can see, there are "holes" in the ping. It seems that even the putty console freezes during theses "pauses".
[root@freenas ~]# uname -a
FreeBSD freenas.local 9.2-RELEASE-p4 FreeBSD 9.2-RELEASE-p4 #0 r262572+17a4d3d: Wed Apr 23 10:09:38 PDT 2014 root@build3.ixsystems.com:/tank/home/jkh/build/9.2.1/freenas/os-base/amd64/fusion/jkh/9.2.1/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
There is nothing in freenas /var/log/messages that could give any clue.
Any advice ?
Youri Andropov
[root@freenas ~]# sysctl hw.physmem
hw.physmem: 8545161216
I'm working on em1 because of the IPMI interface.
[root@freenas ~]# ifconfig
em0: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=4219b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,WOL_MAGIC,VLAN_HWTSO>
ether 00:25:90:72:2e:5d
media: Ethernet autoselect
status: no carrier
em1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9014
options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO>
ether 00:25:90:72:2e:5c
inet6 fe80::225:90ff:fe72:2e5c%em1 prefixlen 64 scopeid 0x3
inet 192.168.0.100 netmask 0xffffff00 broadcast 192.168.0.255
nd6 options=23<PERFORMNUD,ACCEPT_RTADV,AUTO_LINKLOCAL>
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x6
bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9014
ether 02:7e:9d:d8:47:00
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: em1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 3 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9014
options=8<VLAN_MTU>
ether 02:17:2d:00:08:0a
status: active
D
dlavigne
Guest
PMS is pretty hardware intensive. Doubling the RAM might make PMS happier.
joeschmuck
Old Man
Which version of PMS? I'm concerned the newest version is a problem with respect to hardware.
That's what she said! ZING!
My buddy was on the latest as of 4 days ago. He was on 15 and is now on 16 since I upgraded him hoping it might help (it didn't).
joeschmuck
Old Man
That is too bad. I haven't upgraded in a long time. I figure that if it's working fine, why mess with it.
Can you roll those changes back and install an older version?
From what I've read once you upgrade you shouldn't downgrade. As far as I know Plex doesn't make the old downloads available anywhere (if you know of a place I'd love to have a link!) so rolling back isn't easy without you keeping the installer.
joeschmuck
Old Man
Nope, I don't know of any place to grab the old versions but I'm sure they exist. I would expect it needs to be a clean install, not just backing up a version.
Youri Andropov
Well, I've updated FreeNAS to version 9.2.1.7 and PMS to version 0.9.9.13.525-amd64, and I still have the problem : a hang of about 12 seconds every ~2 minutes...
I don't see anything with 'top' in the jail when PMS freezes. It seems that only the network traffic is frozen.
You know... jumbo frames are not recommended because it causes all sorts of random havoc with network's that aren't designed for jumbo frames. Since you just said network traffic just stopped I immediately looked at your MTU...
You might want to get rid of the idea of jumbo frames. They do not add throughput despite popular belief. At least, not unless you have a very very specific reason for a non-standard packet size. Even then, you are almost always talking all commercial-grade hardware at that point.
Youri Andropov
I reverted to standard frames (MTU 1500), but it didn't help ... :/
I'm thinking now about doubling my 8 GB memory.
