SOLVED FreeNAS failed to integrate with Samba DCS
joesnow1234
Hi, I am builing a samba to act as AD DCs, and plan to integrate with FreeNAS ( latest version
FreeNAS-11.0-U2 (e417d8aa5) so that users could restrict to access their owned folders of SMB shares.etc.
I first create a CA named CA in FreeNAS( System =>CAs) with common name freenas.xxx.com, and then sign a certificate with this CA with common name pdc.xxx.com , follow this instruction
https://forums.freenas.org/index.php?threads/cant-join-to-samba-ad-dc.43513/
config snippest of smb.conf is
		idmap_ldb:use rfc2307 = yes
		tls enabled  = yes
		tls keyfile  = /usr/var/lib/samba/private/tls/key.pem # This is certificate signed by CA
		tls certfile = /usr/var/lib/samba/private/tls/cert.pem # This is the corresponding key of key.pem, see above.
		tls cafile   = /usr/var/lib/samba/private/tls/ca.pem	#  This is CA pem, in CA of FreeNAS.
The attachment is directory service.
when I click "save" button, errors raise up with
  • {'desc': 'Connect error', 'info': 'error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed (unable to get local issuer certificate)'}
juding from error, it seems that FreeNAS does not recognize CA's ceritificate(ca.pem) . If it's centos /debian I would like to add ca.pem to system cert store and update-ca-cert. But for FreeNAS, I don't know how.
So what's wrong with my setup? I also wonder where does the related log locate? /var/log/messages shows nothing useful.
Thanks.
Artion
Is the AD DC another system, or the FN box? Will the FN box be the CA or you generate the certificates elsewhere? If this is the case, have you tried to import the CA certificate as in the image below?
joesnow1234
Yes AD DC is built with Samba 4.6.6( the latest version) and its ip is 172,16.234.204.
While FreeNAS is 172.16.234.206 .
I generated CA (ca.pem) on FreeNAS ( System ->CAs) and then signed a cert/key with this CA for Samba DC, as mentioned in the post cert.pem/key.pem.
So FreeNAS is the CA.
joesnow1234
Oh, I finally fingure out the root cause.
I only add certs/CA on the first DCs, but juding from log, FreeNAS tried to connect the 2nd one. Which caused the weird problem.
BTW, the detailed log located at '/var/log/debug.log.
Create CA and import to FreeNAS also works.
Artion
Is this issue solved? Consider editig the post and adding as Solved...:)
Artion
This is how it's done:
1. Click on Thread Tools -> Edit Title
2. Select SOLVED in the Prefix dropdown menu
3. Save changes
