I'm learning as I go so this may be obvious to some of you and I'm sorry. I've searched for hours and tried several suggested fixes but haven't solved my problem yet.
Below is the log file from SMB but there is several errors/failures and I don't know which direction to go.
Thanks in advance!
[2020/08/06 20:53:47.011582, 0] ../source4/smbd/server.c:587(binary_smbd_main)
samba version 4.9.13 started.
Copyright Andrew Tridgell and the Samba Team 1992-2018
[2020/08/06 20:53:47.387508, 0] ../source4/smbd/server.c:773(binary_smbd_main)
binary_smbd_main: samba: using 'standard' process model
[2020/08/06 20:53:47.415170, 0] ../source4/dsdb/common/util.c:1815(samdb_reference_dn_is_our_ntdsa)
[2020/08/06 20:53:47.418106, 0] ../source4/lib/tls/tlscert.c:72(tls_cert_generate)
[2020/08/06 20:53:47.425787, 0] ../lib/util/become_daemon.c:136(daemon_ready)
Failed to find object (null) for attribute fsmoRoleOwner - Cannot find DN (null) to get attribute fsmoRoleOwner for reference dn: Unsupported critical extension 1.2.840.113556.1.4.529
Attempting to autogenerate TLS self-signed keys for https for hostname 'FREENAS.'
[2020/08/06 20:53:47.437149, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
[2020/08/06 20:53:47.447610, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
daemon_ready: daemon 'samba' finished starting up and ready to serve connections
task_server_terminate: task_server_terminate: [kdc: krb5_init_context samdb RODC connect failed]
[2020/08/06 20:53:47.461228, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
task_server_terminate: task_server_terminate: [kccsrv: Failed to connect to local samdb: WERR_DS_UNAVAILABLE
task_server_terminate: task_server_terminate: [dreplsrv: Failed to connect to local samdb: WERR_DS_UNAVAILABLE
[2020/08/06 20:53:47.521498, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
[2020/08/06 20:53:47.529461, 0] ../source4/smbd/server.c:371(samba_terminate)
task_server_terminate: task_server_terminate: [Failed to obtain server credentials, perhaps a standalone server?: NT_STATUS_CANT_ACCESS_DOMAIN_INFO
samba_terminate: samba_terminate of samba 5313: kdc: krb5_init_context samdb RODC connect failed
[2020/08/06 20:53:50.667097, 0] ../source4/lib/tls/tlscert.c:146(tls_cert_generate)
Unable to save certificate in /var/db/samba4/private/tls/cert.pem parent dir exists ?
[2020/08/06 20:53:50.667555, 0] ../source4/lib/tls/tlscert.c:174(tls_cert_generate)
TLS certificate generation failed
[2020/08/06 20:53:50.667843, 0] ../source4/lib/tls/tls_tstream.c:1232(tstream_tls_params_server)
TLS failed to initialise cafile /var/db/samba4/private/tls/ca.pem - Error while reading file.
[2020/08/06 20:53:50.673828, 0] ../source4/ldap_server/ldap_server.c:1174(ldapsrv_task_init)
ldapsrv failed tstream_tls_params_server - NT_STATUS_CANT_ACCESS_DOMAIN_INFO
[2020/08/06 20:53:50.674090, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
task_server_terminate: task_server_terminate: [Failed to startup ldap server task]
[2020/08/06 21:13:16.247506, 0] ../source4/smbd/server.c:587(binary_smbd_main)
[2020/08/06 21:13:16.570476, 0] ../source4/smbd/server.c:773(binary_smbd_main)
[2020/08/06 21:13:16.609082, 0] ../source4/dsdb/common/util.c:1815(samdb_reference_dn_is_our_ntdsa)
[2020/08/06 21:13:16.617111, 0] ../source4/lib/tls/tlscert.c:72(tls_cert_generate)
[2020/08/06 21:13:16.625670, 0] ../lib/util/become_daemon.c:136(daemon_ready)
[2020/08/06 21:13:16.632584, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
[2020/08/06 21:13:16.636281, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
[2020/08/06 21:13:16.639853, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
[2020/08/06 21:13:16.735334, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
[2020/08/06 21:13:16.767724, 0] ../source4/smbd/server.c:371(samba_terminate)
samba_terminate: samba_terminate of samba 3030: kdc: krb5_init_context samdb RODC connect failed
[2020/08/06 21:13:19.284220, 0] ../source4/lib/tls/tlscert.c:146(tls_cert_generate)
[2020/08/06 21:13:19.285213, 0] ../source4/lib/tls/tlscert.c:174(tls_cert_generate)
[2020/08/06 21:13:19.381071, 0] ../source4/lib/tls/tls_tstream.c:1232(tstream_tls_params_server)
[2020/08/06 21:13:19.572450, 0] ../source4/ldap_server/ldap_server.c:1174(ldapsrv_task_init)
[2020/08/06 21:13:19.642509, 0] ../source4/smbd/service_task.c:36(task_server_terminate)
[2020/10/19 19:12:29.735465, 0] ../source4/smbd/server.c:587(binary_smbd_main)
Thanks in advance!
