joelmusicman
- Feb 20, 2014
Greetings imnoob. Since my post count is very low, I'll just introduce myself by saying that I've been trolling the site for a few months and have my mITX build up and running for about a month, configured with ECC and many of the best practices from other threads regarding scrubs, etc. I looked into the ESXi and decided against after reading Cyber's numerous threads.
Key points:
1. You said your data is very important to you. I assume this is why you're looking at FreeNAS to begin with. If you throw away ZFS, you're also throwing away most of the benefits of using FreeNAS vs. a "dumb" share from another OS. Once you do that, then the question becomes, "why virtualize at all?"
2. Hardware RAID vs FreeNAS reliability. Hardware RAID might have the edge if you don't have a UPS solution. However, you're also handcuffed to your HP hardware, and if something goes down in 4 years, you'll probably need to replace with the exact same hardware instead of using the opportunity to upgrade in the process.
It really comes down to what you're ACTUALLY trying to accomplish. If your end-goal is just to serve media to home PCs and maybe a webserver, FreeNAS plugins and jails can be configured to do all of that. Torrents and Usenet can be automated to grab TV, movies, and music, Plex can stream across the web, webservers can be configured in jails, etc. There's NO reason to virtualize in this case. Either use FreeNAS the way it was intended, or use a different OS with your hardware RAID.
Key points:
