johnnytsunami
- Sep 13, 2018
I have a supermicro server that has two HBA controllers. It has 6 drives, two with 3TB, two 164GB and 2 1TB HDDs.
Initially I was having trouble with getting the drives to show up but after using ctrl-c, I was able to enable the cards and see the hard drives connected.
I installed FreeNas 11 on the server but when I go into the FreeNas itself to configure the volume, it does not show all the drives.
Am I missing something?
Update:
The goal is to create a location for storing huge amounts of data that would require multiple TB of data.
I ave 2 HBA cards (both SAS9210-8i)
HDD:
ATA WDC WD1002FBYS-0 0C06 - 1TB
HITACHI HUS723030ALS640 - 3TB
DELL ST3146356SS - 146 GB
MOTHERBOARD: x9dri-ln4f+
FreeNAS 11
I have FreeNAS installed and I can view 4 disk which are my TB HDD's. I can not see the 146 GB HDDs. Using ctrl-c I was able to see the HBA adaptors and see its topology. I can only see 2 drives per controller.
Also when creating a volume it only allows me to use about 4.5 TB of space. I can see the other drives when I view all the disk but I can only create a volume worth 4.5TB.
Anything helps and I appreciate the help of the community.
Update:
HDD:
FreeNAS 11
