I am planning to configure a system with 20 Hard disk of 2 TB . So I have to create a single pool or I can create two volumes of 10 each. Further I am thinking to configure both the volumes in raidz2 configuration.
I am planning to buy a supermicro xeon based processor server and 32 GB ECC Ram.
Kindly guide if I am planning correctly or please suggest.
When I go to http://www.servethehome.com/raid-calculator/
It tells me I will get about 32 TB of usable space using 20 x 2 TB hard disks.
Please guide me (technology champions) if I can create two volumes and both in raidz2 or you suggest something different!
Your kind suggestion will be highly appreciated and helpful!
Thanks,
Thanks,
