Freenas causing problems with other devices on the network?
JamesDH
I have a machine shop and my machines are connected to the network, they are running Linux for the control software and I assume (can't find data) that they are using SMB for networking communications.
Last year I started having difficulty connecting to my machines. They had been setup as a mapped network drive on several computers in the office.
Last year I started having trouble connecting. I did all the physical checks. I studied microsoft updates and posted on the forums. I kept getting a response that Microsoft was having trouble with SMB so I chalked it up to that.
Recently we had a USB crash in our freenas server (older machine running freenas 9.11) It was down for a day or so while we worked on getting it back up.
While it was down I noticed that I no longer had problems accessing the machines. It would connect immediately and stay connected all day.
That made me think it might have been something with Freenas.
Yesterday we brought the server back on line and sure enough. I am once again having difficulty connecting to my machines.
Any idea what might be causing our problem? Any fixes?
I only activated the CIFS service for sharing. I assume it uses SMB?
Thank you
James
There has never been a FreeNAS 9.11 release. There was 9.1.1, and there was 9.10, but never 9.11. Any of these would be very old, and you'd be strongly encouraged to upgrade to at least 11.3.
Alecmascot
I suggest you might have Master Browser issues ?
JamesDH
I'm sorry.
I forgot to mention that when I made the new USB I used the latest version. 11.3
So, what ever it is doing. it did it in the old version and is doing it in the new version as well.
I just did a test.
I compiled some code for the mill and went to move it over to the mill which is set up as a mapped drive.
When I attempted to connect to the mill it froze briefly and gave me an error and would not connect. This is typical of how it's been gong for the past 5 months. If I keep clicking on the drive, it eventually lets me in and I can copy the file over. This takes about 2 minutes.
For the test I unplugged the NAS server and waited a minute and tried to access the mill. BOOM, let me right in and copied the file over without issue.
Typically once I get access to the remote drive I have a minute or two of unrestricted access, so if I stop doing anything with the drive I have to go through the above again.. clicking for 2 minutes to let me back in.
Master browser? Is NAS setup by default to be a master browser? If so, how to turn it off.
I just want a file server.. nothing more, nothing less.
Alecmascot
I would check from windows to see who is master browser.
If you disable SMB Service in FreeNAS does it have the same effect as disconnecting the FreeNAS server ?
Check for duplicate IP addresses.
Look at ARP to see that everything looks kosher.
joeschmuck
Old Man
If they review each post, shouldn't the moderators catch this kind of thing?
Yes, we do catch things like this periodically, but not always. Fixed.
I think the problem here is you are saying things that do not line up with FreeNAS/TrueNAS. I have never heard of a Master Browser (that should tell you something about FreeNAS) on a file server. While I see that you have been a long time member here since 2015 so I find this question odd coming from someone who I would think were familiar with this software. I would recommend that you read the User Guide for FreeNAS/TrueNAS, and know that FreeNAS/TrueNAS is a full featured file server that you can add on some pretty amazing stuff if desired.
no_connection
Think of it as DNS for a workgroup, it's pretty much to keep track of host name and IP so that when you type \\workstation into file browser it will find the machine. The "Master Browser" keeps track of those names when it comes to windows workgroup. By defult FreeNAS acts as master browser but you can uncheck it. If no master browser is found it is elected automatically among the workgroup.
Alecmascot
Use LANScan for win10 from here:
There is a settinging SMB service (advanced) for these things.
joeschmuck
Old Man
Thanks, I did not know that.
pschatz100
If you are trying to connect from Windows, maybe it has an issue with the version of SMB that FreeNAS is using. Try leaving the FreeNAS computer on the network but turn off the SMB service. If your problems go away, then I would suggest you have a conflict with different SMB versions.
JamesDH
Update:
Dug into the master browser idea a little and here is what I found.
Using the Lanscan I see that the Freenas server is registered as the master. I also see where one windows machine is also registered as the master. Machine varies and appears to be random.
There is a checkbox for master browser in the settings for SMB. Unchecking it, rebooting and it still shows up as master.
Possible bug?
However, so far today I am able to access the mill freely with no "waiting" period.
We'll see how it goes as the day wears on.
