Victor Tanvui
- May 31, 2014
I've got the following setup
Internet ------------- Router -----------FreeNAS box ----------network
on FreeNAS BOX
bridged to native vlan interface
As far as I can tell routes are setup OK (static routing). The problem is that I can't ping end to end (from the VPN client to the 10.15.0.0/24 network). Ping between the OpenVPN client and the FreeNAS box works and also pings from the 192.168.1.0/24 network to the 10.15.0.0/24 network work as well.
Any ideas why the FreeNAS box won't forward packets that come from the 10.16.0.0/24 network?
On Linux I know there's something called Reverse Path Filtering which has caused me some problems of the kind in the past, but I can't find anything like it on FreeBSD.
Thanks in advance.
192.168.1.0/24 10.15.0.0/24
(native vlan) (vlan 3)
OpenVPN jail|
on FreeNAS BOX
| (10.16.0.0/24)
OpenVPN client| (10.16.0.0/24)
Thanks in advance.
