OpenVPN gateway in Jail
michael.keller
Hi
I'm a bit stuck at the moment and was hoping that maybe someone could give me a hint what I might be doing wrong....
The main goal is to create a replication task to my second (offsite) freenas. After googling and reading through the forum, the concept to create an openVPN client jail to act as a gateway for the sending freenas box seemed great. I think I've created the opvenVPN jail successfully (pinging my second offsite freenas works, but strangely I can't ssh into my second freenas box within the openVPN jail - I don't know if ssh in a jail is supposed to work out of the box or not...).
The problem is, that from the first freenas box (the one with the openVPN jail), I can't ping the second freenas box via my openVPN jail....and I've no idea what I'm doing wrong, or what I'm missing? I've tried a couple of things other people were suggesting regarding the general setup-up of an openVPN client jail, but unfortunately I've had no success....
The openVPN seems to be configured correctly. When I copy all the openVPN client files that I am using for the jail to my desktop I can connect without any issues. I think, the problem is the communication between the local freenas box and the openVPN jail...
My setup looks like this:
192.168.1.0/24 - local lan
192.168.1.70 - local freenas
192.168.1.111 - local openVPN jail
172.16.0.1 - offsite router with openVPN Server
172.16.0.0/24 - offsite lan
172.16.0.7 - offsite freenas
10.8.0.0/24 - not so sure, I think this is the offsite VPN lan
[root@freenas ~]# netstat -rn
Routing tables
Internet:
Destination		Gateway			Flags	 Netif Expire
default			192.168.1.1		UGS		igb0
127.0.0.1		  link#5			 UH		  lo0
172.16.0.0/24	  192.168.1.111	  UGS		igb0
192.168.1.0/24	 link#1			 U		  igb0
192.168.1.70	   link#1			 UHS		 lo0
[root@freenas ~]# traceroute 172.16.0.7
traceroute to 172.16.0.7 (172.16.0.7), 64 hops max, 40 byte packets
 1  ovpn (192.168.1.111)  0.220 ms  0.152 ms  0.144 ms
 2  * * *
 3  * * *
 4  * * *
 5  * * *
 6  *^C
root@ovpn:/ # cat /etc/rc.conf
portmap_enable="NO"
sshd_enable="NO"
sendmail_enable="NO"
sendmail_submit_enable="NO"
sendmail_outbound_enable="NO"
sendmail_msp_queue_enable="NO"
hostname="ovpn"
devfs_enable="YES"
devfs_system_ruleset="devfsrules_common"
inet6_enable="YES"
ip6addrctl_enable="YES"
openvpn_enable="YES"
openvpn_if="tun"
openvpn_configfile="/usr/local/etc/openvpn/openvpn.conf"
gateway_enable="YES"
firewall_enable="NO"
root@ovpn:/ # netstat -rn
Routing tables
Internet:
default			192.168.1.1		UGS	 epair0b
10.8.0.0/24		10.8.0.1		   UGS		tun0
10.8.0.1		   link#3			 UH		 tun0
10.8.0.5		   link#3			 UHS		 lo0
127.0.0.1		  link#1			 UH		  lo0
172.16.0.0/24	  10.8.0.1		   UGS		tun0
192.168.1.0/24	 link#2			 U	   epair0b
root@ovpn:/ # traceroute 172.16.0.7
 1  10.8.0.1 (10.8.0.1)  2.528 ms  2.371 ms  2.335 ms
 2  172.16.0.7 (172.16.0.7)  2.725 ms  2.794 ms  2.735 ms
Any hints what I might be doning wrong are appreciated!
Thanks
Michael
michael.keller
no, not yet....
