I've installed openvpn client in a jail - which is working fine (guide)
now I want to use the vpn connection with the deluge jail
Following the FreeBSD as router guideline
I've set
and set the vpn jail as gateway in deluge
but I cannot reach any destination
traceroute from deluge client:
traceroute from openvpn client:
I've tried to enable the firewall following this guide: step-by-step-to-install-openvpn-inside-a-jail
but still no luck
what am I missing?
thanks
I've set
gateway_enable="YES" in /etc/rc.confand set the vpn jail as gateway in deluge
root@deluge_1:/ # traceroute 1.1.1.1 traceroute to 1.1.1.1 (1.1.1.1), 64 hops max, 40 byte packets 1 192.168.178.247 (192.168.178.247) 0.101 ms 0.050 ms 0.046 ms 2 * * * 3 * * * 4 * ^C root@deluge_1:/ #
root@openvpn_1:/ # traceroute 1.1.1.1 traceroute to 1.1.1.1 (1.1.1.1), 64 hops max, 40 byte packets 1 10.8.0.1 (10.8.0.1) 32.404 ms 32.051 ms 33.913 ms 2 gw.ipv4.xxx.net (x.x.202.1) 33.877 ms 31.707 ms 31.016 ms 3 ip-77-21.xxx.net (x.x.77.21) 32.146 ms 33.688 ms 33.707 ms 4 cloudflare.xxx.net (x.x.198.68) 31.885 ms 33.228 ms 31.819 ms 5 one.one.one.one (1.1.1.1) 34.249 ms 33.530 ms 31.195 ms root@openvpn_1:/ #
but still no luck
what am I missing?
thanks
