dilod97118
- Aug 7, 2020
Hello, I've just finished installing FreeNAS on my new NAS box. Everything worked flawlessly until I tried scrubbing the boot pool. I tried reinstalling the system 3 times, used different flash drives. I checked the ISO file's checksum too.
The system has 32TB of storage (in RAID-Z2) and 16GB of ECC-RAM.
This is the output of 'zpool status -vx':
The system SSD is a new 120 GB Western Digital Green mSata drive (WDS120G2G0B).
What is the source of this problem?
Is there any way for me to fix it?
Thanks
pool: freenas-boot state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0 days 00:00:03 with 18 errors on Thu Aug 7 15:25:58 2020 config: NAME STATE READ WRITE CKSUM freenas-boot DEGRADED 0 0 27 ada4p2 DEGRADED 0 0 54 too many errors errors: Permanent errors have been detected in the following files: <metadata>:<0x2c> <metadata>:<0x44> <metadata>:<0x7e> <metadata>:<0x8f> <metadata>:<0x90> <metadata>:<0x92> <metadata>:<0x93> freenas-boot/ROOT/default:<0x0> //root/.zsh-histfile freenas-boot/ROOT/default@2020-08-07-11:14:56:/usr/local/lib/python3.7/site-packages/onedrivesdk/request/__pycache__/permission_request_builder.cpython-37.opt-1.pyc freenas-boot/ROOT/default@2020-08-07-11:14:56:/usr/local/lib/python3.7/site-packages/asyncssh/__pycache__/pattern.cpython-37.opt-1.pyc
Thanks
