David Radford
- Aug 17, 2015
I just ordered a bunch of hardware for a local Print Shop and I have a couple questions about setup. First, the hardware:
Xeon 1220v3
Supermicro MBD-X10SL7-F-O
Crucial 16GB (2x8GB) ECC Registered DDR3 1600
6x Seagate Constellation ES.3 (SAS)
2x Seagate Barracuda 500GB (SATA)
NORCO RPC-2008 2U Rackmount chasis
iStarUSA TC-2U/50-80 500W PSU
The 2x Barracudas will be Raid0 and ESXi + VMs will be installed on that.
The 6x Constellations will be a 4 drive RaidZ2 with 2 active spares.
1) Can I pass the LSI 2308 directly to the FreeNAS VM through the vSphere client, or does that only work with PCI HBA cards? What do I need to do to give FreeNAS direct access to these HDD's?
2) I've seen a lot of mentions of having to flash this mobo to IT mode: Is this just if you want extra SATA ports or will this still be needed if I'm using SAS drives? Never flashed a mobo before so I'm not sure what the ramifications of this are.
Any help or pointers would be much appreciated. I'm really looking forward to this build!
-David
Xeon 1220v3
-David
