You know what. I must have been in a sleep-deprived haze. I used Joshua's 0.9.2 pbi. It's completely possible to build your own but then it requires writing a script to autostart it and setting the web gui address, etc. It's annoying.And after those steps you simply started it with service syncthing restart or did you have to copy it or do anything else?
Apart from that, where did you find above steps, maybe I can go read up more on it?
Once I get the PBI built ontop of the new FreeBSD port (sometime in the next few weeks) updates should quickly to the FreeNAS plugin. All I gotta do is recomple the PBI and request the FreeNAS maintainers add it to the repo, I'll try to do this weekly.go to Plugins -> Installed and you will see an update button. but if your current version is less than the version listed in Plugins -> Available, it will downgrade you.
It is best to setup a standard jail and download install Syncthing manually. since PBI dont get updated as fast as the application does. Look at ownCloud its still on version 6.x when the application is already at 7.x.
From your 0.9.2 pbi listed here https://bugs.freenas.org/issues/5706, 'service syncthing upgrade' gives the errormaybe a week or two. gotta update btsync first, plus haven't had much time but it's on my list.
older versions of my pbi you could run 'service syncthing upgrade' this will get you the latest.
/usr/local/etc/rc.d/syncthing: unknown directive 'upgrade'. Usage: /usr/local/etc/rc.d/syncthing [fast|force|one|quiet](start|stop|restart|r cvar|status|poll)
Sorry I haven't been able to do this. It's something I've wanted to do for a while but a lot of other things have taken priority.Hi
I'm to interessted on update the Syncthing to the newest version 0.10.2, it has an auto-update system, and maybe, after this, the Syncthing should do autoupdate automaticaly, without the pbi, i think, should work.
After this, i think, should not need to do a pbi for every new version of Syncthing. Maybe, just one more time, if the Syncthing would be ported to ind.ie as Pulse, renamed.
Sorry for my bad english, but, i think, you understand what i mean.
Many thanks to Joshua for new pbi in advance. Hope it will be soon on the plugins of FreeNAS to see the new version of Syncthing, because, the 0.8.19 from 9 july is very old now, and many things has been changed from this version.
Thanks
This is what I did and it works great! - thanks Josh!!!Hi
Thanks
As always with my plugins, there should be a link to the (default) URL for the plugin in the FreeNAS "Edit" menu.I tried installing syncthing under the new beta 9.3. It seems to have worked, but can somebody please post the proper URL to get into the webgui? I of course know have the URL of the jail, but how do I get into the setup? Thanks.
Left navigation pane. Go to Plugins>Syncthing. You will have a popup window with a link to the GUI. In my case it's https://jailIP:8080/
