[FreeNAS 9 Plugin] - Syncthing
Silwanyx
Hi Joshua
Just to remaind you, it would be great if you could now add the new syncthing 0.13.2 (at this time) to standard installation of FreeNAS available plugin, because, it is not backward compatible with 0.12 or any other old versions, it has new database system (it create a new database folder and system: index-v0.13.0.db on config), and this is not compatible with older versions.
Here you have Infos about this new 0.13.x Version:
https://forum.syncthing.net/t/syncthing-v0-13-2-and-v0-12-25-released/7421
https://github.com/syncthing/syncthing/releases/tag/v0.13.2
Would great, if you can change the old 0.12.2 to the new one.
Thanks
Regards
Joshua Parker Ruehlig
Hi Joshua
Thanks
Regards
good to know, thanks.
ok, I'll put updating this plugin on my to do list. unfortunately, at the moment I am pretty strapped for time so I dont think I'll be able to address this for a while.
Soloam
Hi all, any one was able to make GUI SSL to work? I replaced the /var/db/syncthing/https-cert.pem and /var/db/syncthing/https-key.pem with my certificate and key, but when I reboot the jail it's reverted back to the old certificate.
Thank you
Silwanyx
Hi all
Just to inform everyone, if someone has the problem with starting the Syncthing plugin after updating it, i found the problem! (If you click on Syncthing plugin button to start it, but, it won't turn "On", it stay "Off")
Here is the steps i have done, and my Syncthing WORK AGAIN:
For some reason, after updating it, the "syncthing" binary on:
"/mnt/(your mnt pool)/jails/syncthing_1/usr/pbi/syncthing-amd64/bin/"
and on:
"mnt/(your mnt pool)/jails/syncthing_1/usr/pbi/syncthing-amd64/bin/ST"
IS NOT THERE, disapeared (on ".../ST" folder not there, but on ".../bin" folder, transformed on "syncthing" symlink folder, which is wrong.
I have simply installed another copy of Syncthing plugin, and checked his folders, and have found, that the binary's from this 2 folders are missing. Perhaps, on:
"mnt/(your mnt pool)/jails/syncthing_1/usr/pbi/syncthing-amd64/bin/"
is transformed in a folder symlink, and the bin was not there.
I have deleted this symlink folder, because, on the other copy of Syncthing plugin, this symlink was not there, and if "syncthing" folder shortcut exist there, you won't be able to copy or to put the synthing binary there. Therefore, you should delete this "syncthing" folder symlink, and put there a copy of synthing binary.
I have just simply copyed the entire "mnt/(your mnt pool)/jails/syncthing_1/usr/pbi/syncthing-amd64/bin" folder from the 2nd installed copy of syncthing plugin to my PC, and from there, copyed to my first Syncthing plugin on "mnt/(your mnt pool)/jails/syncthing_1/usr/pbi/syncthing-amd64/bin/", but, it was just this 2 binary files that was missed there, and this was the problem, if i clicked on FreeNAS GUI to start the Syncthing plugin, the indicator won't turn to "On", just keep stay off.
I hope this would help many people out there with the starting Syncthing plugin after updating it.
Salutations.
Soloam
worked like a charm, thank you Silwanyx
Silwanyx
Glad to hear it works for you, @Soloam
Maybe, @Joshua Parker Ruehlig should check this, if can fix it, to not delete or transform the binary's to symlink, on update.
Or, if deleting the old one, to make shure, that the new binary's are successfully copyed on it's places, where should be.
chrisada
Thanks, @Silwanyx that worked flawlessly!
Your diagnostic is spot on. What I did was
  • Installed a 2nd copy of SyncThing plugin as syncthing_2 (I didn't know you can do that!)
  • SSH into my 9.10 installation as root
  • Delete the symlink syncthing from mnt/(your mnt pool)/jails/syncthing_1/usr/pbi/syncthing-amd64/bin
  • Copy syncthing binary files from syncthing_2 to syncthing_1 (2 times, under /bin and /bin/ST )
And now syncthing_1 is able to start. It also updated itself to version 0.13.7 to 0.13.9 automatically.
crap, sorry I didn't test updates. I needed a clean way to have the syncthing binary in its own folder for updating purposes.
but obviously what I did, didn't work across updates. =\
I'll explore this a bit and see there's a better way to handle updates.
hmm, I think before I did this with a symlink, and the way I named the folder broke things. the new naming should work for future updates I think. sorry guys
chrisada
Always extremely appreciative of what you have done for us with all the plugins!
Sent from my Nexus 6P using Tapatalk
SumitB
Can you please provide a step-by-step about doing this? I can install the 2nd instance of syncthing. How to delete the symlink and get it working from there?
Here's a solution to fix an upgraded syncthing plugin. If you could test, that would be great.
rm -r /usr/pbi/syncthing-amd64/bin/syncthing
fetch "https://github.com/syncthing/syncthing/releases/download/v0.13.9/syncthing-freebsd-amd64-v0.13.9.tar.gz"
tar -zxf syncthing-freebsd-amd64-v*.tar.gz
install -o syncthing syncthing-freebsd-amd64-v*/syncthing /usr/pbi/syncthing-amd64/bin/ST
rm -r syncthing-freebsd-amd64-v*
SumitB
Where do I execute these commands. Sorry for being such a noob!
nikzim
When I try to execute the second step (fetching syncthing v0.13.9 from github) I get an SSL certificate verification failure.
Certificate verification failed for /C=USJ/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert SHA2 Extended Validation Server CA
47226:error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed:/usr/src/secure/lib/libssl/../../../crypto/openssl/ssl/s3_clnt.c:997:
fetch: https://github.com/syncthing/syncthing/releases/download/v0.13.9/syncthing-freebsd-amd64-v0.13.9.tar.gz: Authentication error
Any idea how to fix this?
older installs of freebsd had this problem.
I think this would fix it. Tell me if it does
pkg install ca_root_nss
cadavor
Thanks joshua for your help.
Any ideas for the release date of plugin update to syncthing 0.14 ?
I'll look into it when I have time, maybe in the next week. I don't keep up with the releases, but I guess a new FreeNAS plugin update is needed each time a major version is updated?
