Hi there,
I have a problem with latest 9.3/may2015 Freenas build I would really appreciate some help.
I have installed a few plugins with no issues, sabnzbd/transmisssion. But I seem to have a problem with sickbeard and plex. The issue is that when installing them Freenas appends a _1 to the end of the install and creates a virtual filesystem mount point also appending with _1.
For example.
sabnzbd_1/sabnzbd_1
However, for sickbeard and plex the Freenas console log is showing that Freenas is looking in sickbeard_3 for the sickbeard_1 install...God knows what's going on here but no matter what I do, I cannot stop Freenas thinking there are 2 instances of the plugin already installed.
I was going to try renaming the mount point to work round it but this isn't supported and likely isn't the best idea for stability sake.
For example.
sabnzbd_1/sabnzbd_1
May 9 00:43:27 freenas manage.py: [freeadmin.navtree:571] Couldn't retrieve http://192.168.1.252/plugins/sickbeard/3/_s/treemenu: timed out
As can be seen here, this is the first instance of sickbeard installed but Freenas is trying to load from an assumption that it's the 3rd/3.
