BSDrocks
- Mar 15, 2015
I'm running FreeNAS 9.3 (latest stable as of today) and latest CrashPlan plugin 3.6.3_1. On the desktop (Linux) I've got CrashPlan 3.7.0. I set it up as it is documented here but I'm always getting the same error on the client side: Unable to connect to backup engine. Retry?
Here are the details of what I did to set it up:
FreeNAS Crashplan Install
Install the crashplan plugin via the web GUI. >> Plugins >> CrashPlan
In the left-hand frame of the FreeNAS web GUI, expand Plugins, then click on Crashplan. Scroll down to accept the Java EULA.
Added storage to the crashplan jail (Do I need this if I'm only backing up what's on the FreeNAS box itself?
I've got /mnt/pond/media Destination /mnt/media/
Go to the FreeNAS CrashPlan jail and run a SSH session
Enable SSHD /etc/rc.conf to enable SSHD
sshd_enable="YES"
and
crashplan_enable="YES"
Added crashplan user who is a member of wheel.
service crashplan start
(starts without errors)
sockstat -l shows it is running A-O.K.
Edited:
/usr/pbi/crashplan-amd64/share/crashplan/conf/my.service.xml
<serviceHost>127.0.0.1</serviceHost> Change 127.0.0.1 to 0.0.0.0
Restarted CrashPlan on FreeNAS
service crashplan stop && service crashplan start
In the Plugin section I turn the CrashPlan plugin to ON.
Client Side Install
Copy my pub key
ssh-copy-id crashplan@ipaddressofjail
Create SSH tunnel to FreeNAS Jail
ssh -L 4200:127.0.0.1:4243 crashplan@ipaddressofjail -N -v -v
Edit the local config file /usr/local/crashplan/conf/ui.properties and uncomment and change the following:
Port to 4200
Servicehost to the IP of your FreeNAS CrashPlan jail
Crashplan Client is 3.7.0 and it always times out w/
Anyone else seen this? Do I need to have the storage setup if I'm not doing anything but back up the stuff on my FreeNAS box? Has anyone seen this issue or is it one of the open bugs?
TIA!
sshd_enable="YES"
and
Edited:
Client Side Install
Copy my pub key
Port to 4200
TIA!
