Hi all,
I had FreeNAS 9.2.1 running on a SuperMicro X7SPA-HF board, running ZFS (4 disks) a couple of disks failed, but it still worked in a degraded state with 2 disks. Then, with major house renovation... it got powered off for about 18 months!
When I brought it back online.... it worked (amazingly). So I bought the ASRock Rack C3758D4I-4L board, new case 32gb RAM new disks with a view to migrating everything to the new device...... this is where the problems started.
My plan was to disconnect the drives from the old unit (9.2.1), stick them in the new case and bring them online in 11.2. Then, add 2 new disks to the pool, and then once everything had settled across the ZFS pool replace one of the older disk with a new one, then do the same for the last disk.
It failed at the first hurdle in that when I connected the 2 disks from the old box, I could not see or import the ZFS pool, nor could I apply the config I'd save from 9.2.1 to the 11.2 box.
So, I thought I'll put them back into the old box, boot up and manually recreate the config, then copy the data over the LAN. Unfortunately, the old box now fails to power up :(
So I'm a bit stuck with how to proceed. I think I need a two step process.
1. I need to get the config upgraded from 9.2.1 to 11.2. This may involve a couple of VMs to allow give me an upgrade path - even if the data disks are not visible.
2. I should be able to try my initial idea of plugging the drives into the new case, but could probably do with some advice on how to import a degraded ZFS and how I might be able to do this via CLI (if necessary).
All ideas very welcome..... I really don't want to loose all of my data.
Many thanks,
Simon.
Many thanks,
Simon.
