Yatti420
- Aug 12, 2012
Hello everybody,
Got inspired and decided to run some speed tests on my freenas box.. Seems to be holding up well using ZFS and not noticing any big performance hits for real life use.. Using http://forums.freenas.org/threads/intel-nic-vs-realtek-nic-performance-testing.10325/ for reference..
Some of the box is cobbled together from older parts laying around.. I did upgrade however and go through lots of troubles initially moving to freenas 8 - 4k align - bad drives.. bad NICs during hardware testing.. Main use for this box is CIFS/streaming pretty lightweight content.. No true HD content yet.. MiniDNLA added aswell.. No SSDs or significant upgrades planned other then more ram.. Lots more ram.. Box was left to idle and MiniDLNA finished scanning before starting any tests.. Traffic was minimized on network.. Both of these onboard NICs aren't optimal.. However I want to avoid purchasing intel NICs at this time.. Just curious what everybody thought of these speeds..
NAS
Freenas 9.1 RC2 - Kingston DataTraveler DT100 USB 3.0
460W Xtreme Power Plus
Gigabyte H77M-D3H REV1.0 (F9)
Pentium G630 @ 2.7ghz
10GB Non-ECC Ram 1333mhz @ 1067mhz
2 x Seagate Barracuda ST2000DM001 ( Individual Drives/Raw Storage/Sata3 ports[NEWSTORE0/NEWSTORE1)
1 x Western Digital WD20EARX (Sata2 port (Mirror 1 [GREENMIRROR]))**
1 x Western Digital WD20EARS (Sata2 port (Mirror 1 [GREENMIRROR]))**
Thermaltake Performance Fan
Atheros Gigabit LAN Onboard
AHCI Enabled - Standard bios settings..
Intel NAS Computer*
Windows 7 Ultimate SP1 - X64
Asus Motherboard
I5-2500K Intel CPU
8GB Ram
1 x SSD
1 x Seagate 1TB HDD
Realtek GBE Gigabit LAN Onboard
Network
1 x Cisco DPC3825 (Modem/Router)
Cat 6 Ethernet Cables
Freenas CIFS Settings Changed
EA Support = On
Dos File Attrib = On
AIO = On
***Possible further changes and/or return to stock settings..
Basic Testing "DD" - #1 (GUI Shell)
<<Removing tmp.dat>>
#2 - Intel NAS Performance Toolkit - NEWSTORE0 (ST2000DM001) (SATA3)
HDVideo_1Play = 97.343MB/s
HDVideo_2Play = 110.620MB/s
HDVideo_4Play = 109.043MB/s
HDVideo_1Record = 213.472MB/s
HDVideo_1Play_1Record =97.641MB/s
ContentCreation = 7.141MB/s
OfficeProductivity = 50.293MB/s
FileCopyToNAS = 324.984MB/s
FileCopyFromNAS = 92.776MB/s
DirectoryCopyToNAS = 5.706MB/s
DirectoryCopyFromNAS = 17.793MB/s
PhotoAlbum = 12.124MB/s
* Test system has 8GB ram potentially skewing Intel NAS Toolkit results..
** Drive accessed before test initialised to ensure drives spinning/operational..
#3 - Intel NAS Performance Toolkit - NEWSTORE1 (ST2000DM001) (SATA3)
HDVideo_1Play = 108.106MB/s
HDVideo_2Play = 115.238MB/s
HDVideo_4Play = 115.674MB/s
HDVideo_1Record = 201.102MB/s
HDVideo_1Play_1Record = 111.479MB/s
ContentCreation = 2.693MB/s
OfficeProductivity = 56.089MB/s
FileCopyToNAS = 260.416MB/s
FileCopyFromNAS = 101.276MB/s
DirectoryCopyToNAS = 10.065MB/s
DirectoryCopyFromNAS = 23.501MB/s
PhotoAlbum = 14.568MB/s
The speeds via CIFS transfers from a wired computer on gigabit seem fine at aprox 95-100MB/s via windows 7 eyeball..DD seems very slow.. I'm going to do some more testing throughout the day.. Seems pretty solid 100MB/s.. Happy with this..
#4 - Intel NAS Performance Toolkit - GREENMIRROR (WD20EARX/WD20EARS)
#5 NEWSTORE0 - Crystal DiskMark (2Pass \ 100MB )
Sequential Read : 110.726 MB/s
Sequential Write : 107.373 MB/s
Random Read 512KB : 107.493 MB/s
Random Write 512KB : 81.825 MB/s
Random Read 4KB (QD=1) : 11.224 MB/s [ 2740.3 IOPS]
Random Write 4KB (QD=1) : 0.256 MB/s [ 62.5 IOPS]
Random Read 4KB (QD=32) : 11.517 MB/s [ 2811.7 IOPS]
Random Write 4KB (QD=32) : 0.258 MB/s [ 63.1 IOPS]
Test : 100 MB (x2)
#6 NEWSTORE1 - Crystal DiskMark (2Pass \ 100MB )
Sequential Read : 110.793 MB/s
Sequential Write : 111.398 MB/s
Random Write 512KB : 80.120 MB/s
Random Read 4KB (QD=1) : 11.254 MB/s [ 2747.6 IOPS]
Random Write 4KB (QD=1) : 0.171 MB/s [ 41.9 IOPS]
Random Read 4KB (QD=32) : 11.473 MB/s [ 2801.1 IOPS]
Random Write 4KB (QD=32) : 0.286 MB/s [ 69.9 IOPS]
Test : 100 MB (x2)
#7 GREENMIRROR - Crystal DiskMark (2Pass \ 100MB )
Sequential Read : 110.960 MB/s
Sequential Write : 109.000 MB/s
Random Read 512KB : 106.998 MB/s
Random Write 512KB : 73.940 MB/s
Random Read 4KB (QD=1) : 11.222 MB/s [ 2739.8 IOPS]
Random Write 4KB (QD=1) : 0.270 MB/s [ 65.8 IOPS]
Random Read 4KB (QD=32) : 11.015 MB/s [ 2689.3 IOPS]
Random Write 4KB (QD=32) : 0.202 MB/s [ 49.2 IOPS]
Test : 100 MB (x2)
#8 NEWSTORE0 - Windows Large File Transfer (11GB TV SHOWS) - +\- 100 MB/s
#9 NEWSTORE1 - Windows Large File Transfer (11GB TV SHOWS) (Teracopy monitor?)
#10 GREENMIRROR - Windows Large File Transfer (11GB TV SHOWS) (Teracopy monitor?)
**** Other tests omitted.. See updated below..
NAS
Intel NAS Computer*
Asus Motherboard
I5-2500K Intel CPU
8GB Ram
1 x SSD
1 x Seagate 1TB HDD
Network
EA Support = On
AIO = On
/mnt/NEWSTORE0]# dd if=/dev/zero of=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 729.069009 secs (147275746 bytes/sec) dd of=/dev/zero if=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 611.827161 secs (175497574 bytes/sec)
/mnt/NEWSTORE1]# dd if=/dev/zero of=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 753.135016 secs (142569632 bytes/sec) dd of=/dev/zero if=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 628.596551 secs (170815736 bytes/sec)
scan: scrub repaired 0 in 0h58m with 0 errors on Tue Jul 9 00:58:40 2013
NAME STATE READ WRITE CKSUM
GREENMIRROR ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/9d1a1ac0-ffb4-11e1-a826-902b346552f2 ONLINE 0 0 0
gptid/9d72ccaf-ffb4-11e1-a826-902b346552f2 ONLINE 0 0 0
errors: No known data errors Code:
/mnt/GREENMIRROR]# dd if=/dev/zero of=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 1316.502962 secs (81560153 bytes/sec) dd of=/dev/zero if=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 697.851722 secs (153863893 bytes/sec) dd if=/dev/zero of=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 1275.665333 secs (84171122 bytes/sec) dd of=/dev/zero if=tmp.dat bs=2048k count=50k 51200+0 records in 51200+0 records out 107374182400 bytes transferred in 701.637923 secs (153033607 bytes/sec)
Test : 100 MB (x2)
Test : 100 MB (x2)
Test : 100 MB (x2)
