FreeNAS 9.1.1 build - hardware failure
turick
Ok! So the saga continues!
I just ordered a new 2TB WD red drive to replace it and will be in tomorrow. The unreadable (pending) sectors count keeps increasing.... this morning it jumped from 17 to 22, and now it's at 33. I'll check back in tomorrow once I replace it with an update!
Thank you all so much for your friendly advice and help!
Edit: Just jumped to 56
turick
now it's up to 126 sectors... just keeps growing.
Just wanted a quick sanity check. When the drive comes in, my goal is to take ada2 offline, shut it down, swap out the drives, bring it back up, then select the new drive and tell it to "Replace Disk".
Anything else I should consider after that? Running a scrub or another long test on the new drive?
turick
Resilvering.... 6h to go. I'll post again tomorrow and hopefully have a happy NAS once again!
joeschmuck
Old Man
Did you run a SMART Long test on the the drive first? If not, just make sure after resilvering is done to run it.
turick
I did not run it beforehand... resilvering is complete and I just kicked off the long test. Will report back again!
turick
Ok ladies and gents, here are the results of the new drives test:
# smartctl -a /dev/ada2
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red (AF)
Device Model:     WDC WD20EFRX-68EUZN0
Serial Number:    WD-WCC4M3PZU9DP
LU WWN Device Id: 5 0014ee 2674aa2d7
Firmware Version: 82.00A82
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri Jan 24 21:13:43 2020 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (27060) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 273) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x703d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   100   253   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       1
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       27
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       0
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       33
194 Temperature_Celsius     0x0022   109   102   000    Old_age   Always       -       38
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%        24         -
[/CODE}
joeschmuck
Old Man
Sounds like all is good again. Make sure that you setup the SMART testing to routinely test the new drive.
Cheers
