Freenas 8.3 and minidlna 1.0.22_3 setup help
fizzgig656
Im trying to set up a plugin minidlna, ive gone over the wiki but cant seen to get it right (i doubt it the kit) dispite keep trying.
ive got my Raidz as
volume raid1
path /mnt/raid1
it has 2 folders Music and video
set up shares;
Video /mnt/raid1/video
music /mnt/raid1/Music
I can see and added files to both from other pc's
got my plugin setup as;
Plugins jail path /mnt/plugin/jail
Jail name pijail
Jail IP address 192.168.0.90
Jail IP Netmask /24
Plugins archive path /mnt/plugin/sw
Got my Mount set up as;
source destination
/mnt/raid1/Music /mnt/plugin/jail/pijail/media
got my miniDLNA set up as;
Friendly name freenas uPnP
Media directory /mnt/plugin/jail/pijail/media
all the rest defaults.
where has i gone wrong, you can tell me in thick as long as its a simple resolution???
help please.
fizzgig656
any help please, i can see the mount is working, why cant i see the mp3 via upnp?
fizzgig656
Yet another question,
am i better to put the plugin jail and software stuff on a USB pen with mount points from raidz to the usb pen, or install it on the hdd raidz and get rid on the usb pen will it stop the HDD from spinning down as i have the power options set to do so!
P.S. the usb pen is a seperate one to the OS.
fizzgig656
It seems using the browse to folder in minislna doest select the location properly. I typed it put started working?
fizzgig656
It seems to have stopped again. Looks like the mounts are not refreshing? Any thoughts
joeschmuck
Old Man
MiniDLNA is very easy to setup. The problem is arranging your source folders properly to support it if you don't want to get into additional parameters settings.
You can only use one mount point.
I recommend you start by moving all the files you want to share into a single folder, maybe called /mnt/raid1/media/ and move the folders /mnt/raid1/media/Video and /mnt/raid1/media/Music into it.
Now delete all your mount points and create one that points from /mnt/raid1/media/ to /mnt/plugin/jail/pijail/media.
Last thing, in the MiniDLNA plugin configuration, make sure Scan on Restart is checked.
Let me know how that works.
If you have any questions on MiniDLNA just ask me. Also the link below in my signature will fix the auto-scanning problem to which there is no other solution at this time and I don't expect to see one anytime soon for FreeNAS. Okay, I don't ever expect to see a solution other than what I created, period. I know there is a new version of MiniDLNA coming out and once I figure out how to compile it properly, I plan to push my fix into it. It would be strictly a FreeNAS/FreeBSD type thing.
As for the USB Flash drive for Plugins... You have read my opinion. I use a Flash drive and have had no problems. There are statistics out there that you can read. I'd say it was a stupid thing to do if it were writing large amounts of data all the time but it's only a small amount of data and not very often. To tell the truth, I only see that USB light flash when I reboot the computer, or MiniDLNA is triggered to scan the media again. I still recommend using a small SSD as they are under $50.00 and you can partition off 10GB for plugins, 8GB for a ZIL, and the rest for an L2ARC or split it for some other use. I plan to write a how-to guide on that in the near future.
fizzgig656
OK thanks I will give it a try. Not been a good weekend, interners gone down two so relying on mobile data. Not good. Does it matter the shared or rather mount points are folder made by windows? I think one of them were?
Cheers
joeschmuck
Old Man
If you can navigate to the mount point using the browser, then it should be fine. You only have problems in FreeNAS with overlapping mount points, meaning any time a mount point specified the same location that is listed in another mount point.
fizzgig656
Sounds like a bit of both. Had a quick look at the rescan issue. Am I right in thinking it only rescans at the mo when freenas is rebooted? If its still not scanning them its something else? Feel like a dick now for not realizing.
only 1 mount
/mnt/raid1 /mnt/plugin/jail/pijail/media
i can see the mounts updating correctly now when i change files about, but minidlna still does not seem to see the files, either at the media root or in folders off media. if i go to the minidlna ip : port it show 0 files still. thoughts?
joeschmuck
Old Man
Yes, MiniDLNA will not automatically rescan as you add, delete, or modify files in the shared areas, not in FreeBSD platforms which FreeNAS is built on. You need to have the rescan checked and if you use my posting to fix the rescanning issue, it will work but it does this by forcing MiniDLNA to stop and then restarts it, not a reboot of the FreeNAS server. Read the thread carefully before doing anything.
The other work around is to stop the MiniDLNA plugin and start it again manually. I like my method better of course.
fizzgig656
erm, may of somehow got it working, think i deleted minidlna and started again. cheers for your help
fizzgig656
and even more thanks, the fix for auto scanning works. I didnt doubt it (doubted my ability to implement) used putty and found it very easy. thanks for the guide. now ive not to try and get XP media centre to see it!!!
fizzgig656
Now I can't seem to turn minidlna off? Unless I turn the plugin off and on again. Any thoughts? Also the hdd wont spin down. They are set for 20minutes spindown
I've not got many files/folders to have a long file/folder name/string.
fizzgig656
does this help. is it one of my HDD on the way out? causing the autoscan to think there is a change and initiating a scan? I know minidlna cant start as ive switch off the plugin. but something aint right?
Dec 2 12:05:54 freenas newsyslog[1586]: logfile first created
Dec 2 12:05:54 freenas syslogd: kernel boot file is /boot/kernel/kernel
Dec 2 12:05:54 freenas kernel: Copyright (c) 1992-2012 The FreeBSD Project.
Dec 2 12:05:54 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Dec 2 12:05:54 freenas kernel: The Regents of the University of California. All rights reserved.
Dec 2 12:05:54 freenas kernel: FreeBSD is a registered trademark of The FreeBSD Foundation.
Dec 2 12:05:54 freenas kernel: FreeBSD 8.3-RELEASE-p4 #0 r241984M: Wed Oct 24 00:57:10 PDT 2012
Dec 2 12:05:54 freenas kernel: root@build.ixsystems.com:/usr/home/jpaetzel/8.3.0-RELEASE/os-base/amd64/usr/home/jpaetzel/8.3.0-RELEASE/FreeBSD/src/sys/FREENAS.amd64 amd64
Dec 2 12:05:54 freenas kernel: Timecounter "i8254" frequency 1193182 Hz quality 0
Dec 2 12:05:54 freenas kernel: CPU: Intel(R) Atom(TM) CPU D2700 @ 2.13GHz (2141.95-MHz K8-class CPU)
Dec 2 12:05:54 freenas kernel: Origin = "GenuineIntel" Id = 0x30661 Family = 6 Model = 36 Stepping = 1
Dec 2 12:05:54 freenas kernel: Features=0xbfebfbff
Dec 2 12:05:54 freenas kernel: Features2=0x40e31d
Dec 2 12:05:54 freenas kernel: AMD Features=0x20100800
Dec 2 12:05:54 freenas kernel: AMD Features2=0x1
Dec 2 12:05:54 freenas kernel: TSC: P-state invariant
Dec 2 12:05:54 freenas kernel: real memory = 8589934592 (8192 MB)
Dec 2 12:05:54 freenas kernel: avail memory = 8241340416 (7859 MB)
Dec 2 12:05:54 freenas kernel: ACPI APIC Table:
Dec 2 12:05:54 freenas kernel: FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
Dec 2 12:05:54 freenas kernel: FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 HTT threads
Dec 2 12:05:54 freenas kernel: cpu0 (BSP): APIC ID: 0
Dec 2 12:05:54 freenas kernel: cpu1 (AP/HT): APIC ID: 1
Dec 2 12:05:54 freenas kernel: cpu2 (AP): APIC ID: 2
Dec 2 12:05:54 freenas kernel: cpu3 (AP/HT): APIC ID: 3
Dec 2 12:05:54 freenas kernel: WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Dec 2 12:05:54 freenas kernel: ioapic0: Changing APIC ID to 8
Dec 2 12:05:54 freenas kernel: ioapic0 irqs 0-23 on motherboard
Dec 2 12:05:54 freenas kernel: lapic0: Forcing LINT1 to edge trigger
Dec 2 12:05:54 freenas kernel: kbd1 at kbdmux0
Dec 2 12:05:54 freenas kernel: hpt27xx: RocketRAID 27xx controller driver v1.0 (Oct 24 2012 00:56:59)
Dec 2 12:05:54 freenas kernel: cryptosoft0: on motherboard
Dec 2 12:05:54 freenas kernel: aesni0: No AESNI support.
Dec 2 12:05:54 freenas kernel: acpi0: on motherboard
Dec 2 12:05:54 freenas kernel: acpi0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: acpi0: Power Button (fixed)
Dec 2 12:05:54 freenas kernel: acpi_hpet0: iomem 0xfed00000-0xfed003ff on acpi0
Dec 2 12:05:54 freenas kernel: Timecounter "HPET" frequency 14318180 Hz quality 900
Dec 2 12:05:54 freenas kernel: acpi0: reservation of 0, 4000 (3) failed
Dec 2 12:05:54 freenas kernel: Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
Dec 2 12:05:54 freenas kernel: acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
Dec 2 12:05:54 freenas kernel: cpu0: on acpi0
Dec 2 12:05:54 freenas kernel: cpu1: on acpi0
Dec 2 12:05:54 freenas kernel: cpu2: on acpi0
Dec 2 12:05:54 freenas kernel: cpu3: on acpi0
Dec 2 12:05:54 freenas kernel: pcib0: port 0xcf8-0xcff on acpi0
Dec 2 12:05:54 freenas kernel: pci0: on pcib0
Dec 2 12:05:54 freenas kernel: vgapci0: port 0x30d0-0x30d7 mem 0xd0200000-0xd02fffff irq 16 at device 2.0 on pci0
Dec 2 12:05:54 freenas kernel: pci0: at device 27.0 (no driver attached)
Dec 2 12:05:54 freenas kernel: pcib1: at device 28.0 on pci0
Dec 2 12:05:54 freenas kernel: pci1: on pcib1
Dec 2 12:05:54 freenas kernel: em0: port 0x2000-0x201f mem 0xd0120000-0xd013ffff,0xd0100000-0xd011ffff,0xd0140000-0xd0143fff irq 16 at device 0.0 on pci1
Dec 2 12:05:54 freenas kernel: em0: Using MSIX interrupts with 3 vectors
Dec 2 12:05:54 freenas kernel: em0: [ITHREAD]
Dec 2 12:05:54 freenas last message repeated 2 times
Dec 2 12:05:54 freenas kernel: em0: Ethernet address: 00:22:4d:80:9c:f6
Dec 2 12:05:54 freenas kernel: pcib2: at device 28.2 on pci0
Dec 2 12:05:54 freenas kernel: pci2: on pcib2
Dec 2 12:05:54 freenas kernel: siis0: port 0x1000-0x107f mem 0xd0004000-0xd000407f,0xd0000000-0xd0003fff irq 18 at device 0.0 on pci2
Dec 2 12:05:54 freenas kernel: siis0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: siisch0: at channel 0 on siis0
Dec 2 12:05:54 freenas kernel: siisch0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: siisch1: at channel 1 on siis0
Dec 2 12:05:54 freenas kernel: siisch1: [ITHREAD]
Dec 2 12:05:54 freenas kernel: uhci0: port 0x30a0-0x30bf irq 23 at device 29.0 on pci0
Dec 2 12:05:54 freenas kernel: uhci0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: usbus0: on uhci0
Dec 2 12:05:54 freenas kernel: uhci1: port 0x3080-0x309f irq 19 at device 29.1 on pci0
Dec 2 12:05:54 freenas kernel: uhci1: [ITHREAD]
Dec 2 12:05:54 freenas kernel: usbus1: on uhci1
Dec 2 12:05:54 freenas kernel: uhci2: port 0x3060-0x307f irq 18 at device 29.2 on pci0
Dec 2 12:05:54 freenas kernel: uhci2: [ITHREAD]
Dec 2 12:05:54 freenas kernel: usbus2: on uhci2
Dec 2 12:05:54 freenas kernel: uhci3: port 0x3040-0x305f irq 16 at device 29.3 on pci0
Dec 2 12:05:54 freenas kernel: uhci3: [ITHREAD]
Dec 2 12:05:54 freenas kernel: usbus3: on uhci3
Dec 2 12:05:54 freenas kernel: ehci0: mem 0xd0304400-0xd03047ff irq 23 at device 29.7 on pci0
Dec 2 12:05:54 freenas kernel: ehci0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: usbus4: EHCI version 1.0
Dec 2 12:05:54 freenas kernel: usbus4: on ehci0
Dec 2 12:05:54 freenas kernel: pcib3: at device 30.0 on pci0
Dec 2 12:05:54 freenas kernel: pci3: on pcib3
Dec 2 12:05:54 freenas kernel: isab0: at device 31.0 on pci0
Dec 2 12:05:54 freenas kernel: isa0: on isab0
Dec 2 12:05:54 freenas kernel: ahci0: port 0x30c8-0x30cf,0x30dc-0x30df,0x30c0-0x30c7,0x30d8-0x30db,0x3020-0x302f mem 0xd0304000-0xd03043ff irq 19 at device 31.2 on pci0
Dec 2 12:05:54 freenas kernel: ahci0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: ahci0: AHCI v1.10 with 4 3Gbps ports, Port Multiplier not supported
Dec 2 12:05:54 freenas kernel: ahcich0: at channel 0 on ahci0
Dec 2 12:05:54 freenas kernel: ahcich0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: ahcich1: at channel 1 on ahci0
Dec 2 12:05:54 freenas kernel: ahcich1: [ITHREAD]
Dec 2 12:05:54 freenas kernel: pci0: at device 31.3 (no driver attached)
Dec 2 12:05:54 freenas kernel: acpi_button0: on acpi0
Dec 2 12:05:54 freenas kernel: acpi_button1: on acpi0
Dec 2 12:05:54 freenas kernel: atrtc0: port 0x70-0x77 irq 8 on acpi0
Dec 2 12:05:54 freenas kernel: atrtc0: Warning: Couldn't map I/O.
Dec 2 12:05:54 freenas kernel: orm0: at iomem 0xcf800-0xd3fff on isa0
Dec 2 12:05:54 freenas kernel: sc0: at flags 0x100 on isa0
Dec 2 12:05:54 freenas kernel: sc0: VGA <16 virtual consoles, flags=0x300>
Dec 2 12:05:54 freenas kernel: vga0: at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
Dec 2 12:05:54 freenas kernel: atkbdc0: at port 0x60,0x64 on isa0
Dec 2 12:05:54 freenas kernel: atkbd0: irq 1 on atkbdc0
Dec 2 12:05:54 freenas kernel: kbd0 at atkbd0
Dec 2 12:05:54 freenas kernel: atkbd0: [GIANT-LOCKED]
Dec 2 12:05:54 freenas kernel: atkbd0: [ITHREAD]
Dec 2 12:05:54 freenas kernel: ppc0: cannot reserve I/O port range
Dec 2 12:05:54 freenas kernel: coretemp0: on cpu0
Dec 2 12:05:54 freenas kernel: coretemp0: Can not get Tj(target) from your CPU, using 100C.
Dec 2 12:05:54 freenas kernel: p4tcc0: on cpu0
Dec 2 12:05:54 freenas kernel: coretemp1: on cpu1
Dec 2 12:05:54 freenas kernel: coretemp1: Can not get Tj(target) from your CPU, using 100C.
Dec 2 12:05:54 freenas kernel: p4tcc1: on cpu1
Dec 2 12:05:54 freenas kernel: coretemp2: on cpu2
Dec 2 12:05:54 freenas kernel: coretemp2: Can not get Tj(target) from your CPU, using 100C.
Dec 2 12:05:54 freenas kernel: p4tcc2: on cpu2
Dec 2 12:05:54 freenas kernel: coretemp3: on cpu3
Dec 2 12:05:54 freenas kernel: coretemp3: Can not get Tj(target) from your CPU, using 100C.
Dec 2 12:05:54 freenas kernel: p4tcc3: on cpu3
Dec 2 12:05:54 freenas kernel: fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Dec 2 12:05:54 freenas kernel: RTC BIOS diagnostic error 80
Dec 2 12:05:54 freenas kernel: Timecounters tick every 1.000 msec
Dec 2 12:05:54 freenas kernel: (noperiph:siisch0:0:-1:-1): rescan already queued
Dec 2 12:05:54 freenas kernel: (noperiph:siisch1:0:-1:-1): rescan already queued
Dec 2 12:05:54 freenas kernel: hpt27xx: no controller detected.
Dec 2 12:05:54 freenas kernel: GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)usbus0: 12Mbps Full Speed USB v1.0
Dec 2 12:05:54 freenas kernel: usbus1: 12Mbps Full Speed USB v1.0
Dec 2 12:05:54 freenas kernel: usbus2: 12Mbps Full Speed USB v1.0
Dec 2 12:05:54 freenas kernel: usbus3: 12Mbps Full Speed USB v1.0
Dec 2 12:05:54 freenas kernel: usbus4: 480Mbps High Speed USB v2.0
Dec 2 12:05:54 freenas kernel: ugen0.1: at usbus0
Dec 2 12:05:54 freenas kernel: uhub0: on usbus0
Dec 2 12:05:54 freenas kernel: ugen1.1: at usbus1
Dec 2 12:05:54 freenas kernel: uhub1: on usbus1
Dec 2 12:05:54 freenas kernel: ugen2.1: at usbus2
Dec 2 12:05:54 freenas kernel: uhub2: on usbus2
Dec 2 12:05:54 freenas kernel: ugen3.1: at usbus3
Dec 2 12:05:54 freenas kernel: uhub3: on usbus3
Dec 2 12:05:54 freenas kernel: ugen4.1: at usbus4
Dec 2 12:05:54 freenas kernel: uhub4: on usbus4
Dec 2 12:05:54 freenas kernel: uhub0: 2 ports with 2 removable, self powered
Dec 2 12:05:54 freenas kernel: uhub1: 2 ports with 2 removable, self powered
Dec 2 12:05:54 freenas kernel: uhub2: 2 ports with 2 removable, self powered
Dec 2 12:05:54 freenas kernel: uhub3: 2 ports with 2 removable, self powered
Dec 2 12:05:54 freenas kernel: uhub4: 8 ports with 8 removable, self powered
Dec 2 12:05:54 freenas kernel: ugen4.2: at usbus4
Dec 2 12:05:54 freenas kernel: umass0: on usbus4
Dec 2 12:05:54 freenas kernel: ugen4.3: at usbus4
Dec 2 12:05:54 freenas kernel: umass1: on usbus4
Dec 2 12:05:54 freenas kernel: ada0 at siisch0 bus 0 scbus0 target 0 lun 0
Dec 2 12:05:54 freenas kernel: ada0: ATA-8 SATA 3.x device
Dec 2 12:05:54 freenas kernel: ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Dec 2 12:05:54 freenas kernel: ada0: Command Queueing enabled
Dec 2 12:05:54 freenas kernel: ada0: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
Dec 2 12:05:54 freenas kernel: ada1 at siisch1 bus 0 scbus1 target 0 lun 0
Dec 2 12:05:54 freenas kernel: ada1: ATA-8 SATA 3.x device
Dec 2 12:05:54 freenas kernel: ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Dec 2 12:05:54 freenas kernel: ada1: Command Queueing enabled
Dec 2 12:05:54 freenas kernel: ada1: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
Dec 2 12:05:54 freenas kernel: ada2 at ahcich0 bus 0 scbus2 target 0 lun 0
Dec 2 12:05:54 freenas kernel: ada2: ATA-8 SATA 3.x device
Dec 2 12:05:54 freenas kernel: ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Dec 2 12:05:54 freenas kernel: ada2: Command Queueing enabled
Dec 2 12:05:54 freenas kernel: ada2: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
Dec 2 12:05:54 freenas kernel: ada3 at ahcich1 bus 0 scbus3 target 0 lun 0
Dec 2 12:05:54 freenas kernel: ada3: ATA-8 SATA 3.x device
Dec 2 12:05:54 freenas kernel: ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Dec 2 12:05:54 freenas kernel: ada3: Command Queueing enabled
Dec 2 12:05:54 freenas kernel: ada3: 476940MB (976773168 512 byte sectors: 16H 63S/T 16383C)
Dec 2 12:05:54 freenas kernel: da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
Dec 2 12:05:54 freenas kernel: da0: Removable Direct Access SCSI-2 device
Dec 2 12:05:54 freenas kernel: da0: 40.000MB/s transfers
Dec 2 12:05:54 freenas kernel: da0: 3854MB (7892992 512 byte sectors: 255H 63S/T 491C)
Dec 2 12:05:54 freenas kernel: da1 at umass-sim1 bus 1 scbus5 target 0 lun 0
Dec 2 12:05:54 freenas kernel: da1: Removable Direct Access SCSI-0 device
Dec 2 12:05:54 freenas kernel: da1: 40.000MB/s transfers
Dec 2 12:05:54 freenas kernel: da1: 7648MB (15663104 512 byte sectors: 255H 63S/T 974C)
Dec 2 12:05:54 freenas kernel: lapic1: Forcing LINT1 to edge trigger
Dec 2 12:05:54 freenas kernel: SMP: AP CPU #1 Launched!
Dec 2 12:05:54 freenas kernel: lapic2: Forcing LINT1 to edge trigger
Dec 2 12:05:54 freenas kernel: SMP: AP CPU #2 Launched!
Dec 2 12:05:54 freenas kernel: lapic3: Forcing LINT1 to edge trigger
Dec 2 12:05:54 freenas kernel: SMP: AP CPU #3 Launched!
Dec 2 12:05:54 freenas kernel: GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Dec 2 12:05:54 freenas kernel: Trying to mount root from ufs:/dev/ufs/FreeNASs1a
Dec 2 12:05:54 freenas kernel: ZFS filesystem version 5
Dec 2 12:05:54 freenas kernel: ZFS storage pool version 28
Dec 2 12:05:55 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Dec 2 12:05:55 freenas ntpd[1803]: ntpd 4.2.4p5-a (1)
Dec 2 12:05:57 freenas ntpd_initres[1809]: host name not found: 0.freebsd.pool.ntp.org
Dec 2 12:05:57 freenas ntpd_initres[1809]: couldn't resolve `0.freebsd.pool.ntp.org', giving up on it
Dec 2 12:05:57 freenas ntpd_initres[1809]: host name not found: 1.freebsd.pool.ntp.org
Dec 2 12:05:57 freenas ntpd_initres[1809]: couldn't resolve `1.freebsd.pool.ntp.org', giving up on it
Dec 2 12:05:57 freenas ntpd_initres[1809]: host name not found: 2.freebsd.pool.ntp.org
Dec 2 12:05:57 freenas ntpd_initres[1809]: couldn't resolve `2.freebsd.pool.ntp.org', giving up on it
Dec 2 12:05:58 freenas smartd[2044]: Device: /dev/ada2, 2836 Currently unreadable (pending) sectors
Dec 2 12:06:01 freenas smartd[2044]: Device: /dev/ada2, 2112 Offline uncorrectable sectors
Dec 2 12:06:24 freenas avahi-daemon[2282]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Dec 2 12:06:30 freenas kernel: bridge0: Ethernet address: 02:c5:fb:53:83:00
Dec 2 12:06:30 freenas kernel: epair0a: Ethernet address: 02:ec:4f:00:09:0a
Dec 2 12:06:30 freenas kernel: epair0b: Ethernet address: 02:ec:4f:00:0a:0b
Dec 2 12:06:30 freenas kernel: epair0a: link state changed to UP
Dec 2 12:06:30 freenas kernel: epair0b: link state changed to UP
Dec 2 12:06:31 freenas kernel: epair0a: promiscuous mode enabled
Dec 2 12:06:31 freenas kernel: em0: link state changed to DOWN
Dec 2 12:06:31 freenas kernel: em0: promiscuous mode enabled
Dec 2 12:06:32 freenas kernel: em0: link state changed to UP
Dec 2 12:28:49 freenas notifier: Stopping jails: pijail192.168.10.46 (192.168.10.46) deleted
Dec 2 12:28:49 freenas kernel: em0: promiscuous mode disabled
Dec 2 12:28:49 freenas kernel: em0: link state changed to DOWN
Dec 2 12:28:49 freenas kernel: epair0a: promiscuous mode disabled
Dec 2 12:28:49 freenas kernel: epair0a: link state changed to DOWN
Dec 2 12:28:49 freenas kernel: epair0b: link state changed to DOWN
Dec 2 12:28:49 freenas notifier: .
Dec 2 12:28:50 freenas kernel: em0: link state changed to UP
Dec 2 12:28:50 freenas avahi-daemon[2282]: Received packet from invalid interface.
Dec 2 12:28:59 freenas notifier: security.jail.allow_raw_sockets: 1 -> 1
Dec 2 12:28:59 freenas notifier: Configuring jails:.
Dec 2 12:29:00 freenas notifier: Starting jails: pijail.
Dec 2 12:29:00 freenas notifier: add net default: gateway 192.168.10.1
Dec 2 12:29:00 freenas kernel: bridge0: Ethernet address: 02:c5:fb:53:83:00
Dec 2 12:29:00 freenas kernel: epair0a: Ethernet address: 02:7a:c6:00:09:0a
Dec 2 12:29:00 freenas kernel: epair0b: Ethernet address: 02:7a:c6:00:0a:0b
Dec 2 12:29:00 freenas kernel: epair0a: link state changed to UP
Dec 2 12:29:00 freenas kernel: epair0b: link state changed to UP
Dec 2 12:29:00 freenas kernel: epair0a: promiscuous mode enabled
Dec 2 12:29:00 freenas notifier: stty: stdin isn't a terminal
Dec 2 12:29:00 freenas kernel: em0: link state changed to DOWN
Dec 2 12:29:00 freenas kernel: em0: promiscuous mode enabled
Dec 2 12:29:00 freenas notifier: /etc/rc: WARNING: $hostname is not set -- see rc.conf(5).
Dec 2 12:29:00 freenas notifier: ELF ldconfig path: /lib /usr/lib /usr/local/lib
Dec 2 12:29:00 freenas notifier: 32-bit compatibility ldconfig path: /usr/lib32
Dec 2 12:29:00 freenas notifier: Creating and/or trimming log files.
Dec 2 12:29:00 freenas notifier: Starting syslogd.
Dec 2 12:29:00 freenas notifier: Clearing /tmp (X related).
Dec 2 12:29:00 freenas notifier: Updating motd:.
Dec 2 12:29:00 freenas notifier: Starting cron.
Dec 2 12:29:00 freenas notifier: wait_on: Command not found.
Dec 2 12:29:02 freenas kernel: em0: link state changed to UP
Dec 2 12:29:23 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.10.40/plugins/transmission/_s/status: HTTP Error 502: Bad Gateway
Dec 2 12:29:23 freenas manage.py: [plugins.utils:71] Couldn't retrieve http://192.168.10.40/plugins/minidlna/_s/status: HTTP Error 502: Bad Gateway
Dec 2 12:29:27 freenas kernel: in6_purgeaddr: err=65, destination address delete failed
Dec 2 12:29:27 freenas kernel: Freed UMA keg was not empty (504 items). Lost 3 pages of memory.
Dec 2 12:29:27 freenas kernel: Freed UMA keg was not empty (44 items). Lost 4 pages of memory.
Dec 2 12:29:27 freenas kernel: Freed UMA keg was not empty (250 items). Lost 5 pages of memory.
Dec 2 12:29:27 freenas kernel: Freed UMA keg was not empty (36 items). Lost 9 pages of memory.
Dec 2 12:29:27 freenas kernel: Freed UMA keg was not empty (55 items). Lost 5 pages of memory.
Dec 2 12:29:27 freenas kernel: hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required
Dec 2 12:29:27 freenas kernel: hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required
Stop refresh
joeschmuck
Old Man
According to this scan the "Plugins" is running, not stopped. Notice the jails have started.
As for MiniDLNA not stopping, did you implement the fix in post#45 of the thread? Although that problem is fixed in the source code, it will not be made public until the next release of the MiniDLNA plugin.
As for your drives not spinning down, that could be a lot of things causing that, not MiniDLNA. In fact MiniDLNA should have no bearing on it at all. Try this little trick, once your FreeNAS has been started and is running, unplug the Ethernet cable from it. If your drives are set to sleep after 20 minutes, check the drives in about 30 minutes to see if they are sleeping. Quite often it's network activity that keeps the drives running. If that works then you need to find the culprit on your network that is checking the drives often.
Cheers
fizzgig656
Cheers for your help again. i have apllied the fix post#45 but i still have problems turning it off, ill keep an eye though, seems ok after a reboot but not if you leave it a while but let me keep and eye on it. also tried the lan out but still not powering down after 35minutes. but again im trying a few things.
fizzgig656
ive been watching it and ive got a usb drive with flashing activity light, and i see the pen flash every 5-10 minutes then the HDD frash away for a 30s to 1 minute.
maybe this will jog a memory? or i did something wrong? ill still keep any eye on it.
joeschmuck
Old Man
It's hard to tell what is going on without knowing everything configured. For instance I don't use transmission which I would assume writes to the flash and possibly your drives very frequently. I don't use FireFly either. The only plugin I use is MiniDLNA. I think you will be doing a lot of trial and error to figure out what is going on. FreeNAS is not a turnkey program, there are things to figure out. It took me about 6 months, while learning to program this beast just to get a very small understanding of this software. I'm not a Linux or BSD person, I'm from the old days where punched cards and machine language ruled. Python and crap like that is over my head right now and I have no ambition to learn it. I learn what interests me, that is all. I want MiniDLNA to run properly as I use FreeNAS as a backup device and to stream movies. My daughter could use the streaming music if she wanted to but she doesn't, but it's there if she wants it.
After you set the spindown time for your drives did you "Shutdown" your computer? I say shutdown, not reboot. The values are not applied until the system is booted. In FreeNAS 9.x this should be fixed but for now it's needed. If your drives fail to spindown while the plugins are turned off and the LAN cable is disconnected, then you must have something setup which keeps looking at the drives. Although it's not fun to do, maybe a clean install is what you need. Grab a new USB flash drive, save your older one. Also save your config file, it may save you a little grief. Load up the new flash drive and leave it basically unconfigured. Auto-Import your pool, setup your spindown time, shutdown and boot up, unplug your lan CABLE, verify your drives spin down. I can give you the commands to force your drives to spin down if this doesn't work.
fizzgig656
OK thanks. Transmission is off anyway at the moment still no internet at home, grrr, I did wonder at a fresh install. I did have the drives spinning down before configing minidlna? Maybe delete the plugin and see then start again? Cheers for your help.
fizzgig656
i thought i was getting somewhere, ive reinstalled freenas, redone the plugin and minidlna, my drives are now spining down, but i cant seem to connect to the webpage. ip:8200 and all is standard setup. i can map to the plugin media folder and see all the media? any thoughts. before i could connect to the webpage and see a tally of the files minidlna had found. :mad: webpage cannot be found is the error. i can see the minidlna name as a UPnP device.
