You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
minidlna error help me plase!
- Status
hello friends
minidlna plugin installed. I gave the first start command but I get an error like this.
"Media directory not accessible! [Mnt/tank/jail/plugin/usr/pbi/minidlna-amd64/homemedia"
I set my minidlna connection is as follows;
/ mnt / tank / HomeMedia to mnt/tank/jail/plugin/usr/pbi/minidlna-amd64/homemedia
Waiting for answers
thank you
hi friends
I do not understand something
my minidlna.log :
[2012/09/07 12:47:03] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/07 12:47:03] minidlna.c:949: warn: Creating new database...
[2012/09/07 12:47:03] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/07 13:19:18] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/07 13:19:28] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/07 23:49:09] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/08 05:06:34] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/08 05:06:35] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/08 08:07:29] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/08 08:07:29] minidlna.c:949: warn: Creating new database...
[2012/09/08 08:07:29] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/08 09:41:56] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/08 09:41:56] minidlna.c:949: warn: Creating new database...
[2012/09/08 09:41:56] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/08 09:44:38] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/08 09:44:48] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/08 10:04:08] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/08 10:04:18] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/08 10:17:16] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/08 10:17:16] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/08 10:20:40] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/08 10:20:40] minidlna.c:949: warn: Creating new database...
[2012/09/08 10:20:40] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/08 10:28:08] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/09 08:00:55] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/09 08:01:05] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/10 07:01:51] upnphttp.c:929: warn: / not found, responding ERROR 404
[2012/09/10 07:01:52] upnphttp.c:929: warn: /favicon.ico not found, responding ERROR 404
[2012/09/10 12:34:13] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/10 12:34:14] minidlna.c:949: warn: Creating new database...
[2012/09/10 12:34:14] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/10 12:44:16] upnphttp.c:929: warn: / not found, responding ERROR 404
[2012/09/10 12:49:47] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/10 12:49:57] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/11 00:26:39] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/11 09:05:22] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/11 09:05:22] minidlna.c:949: warn: Creating new database...
[2012/09/11 09:05:22] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 01:02:28] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/14 01:02:38] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/14 09:39:28] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 09:39:28] minidlna.c:949: warn: Creating new database...
[2012/09/14 09:39:28] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 09:40:41] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/14 09:40:51] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/14 09:42:41] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/14 09:42:41] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/14 09:45:51] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 09:45:51] minidlna.c:949: warn: Creating new database...
[2012/09/14 09:45:51] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 09:53:07] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 09:53:07] minidlna.c:949: warn: Creating new database...
[2012/09/14 09:53:07] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 09:54:28] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 09:54:28] minidlna.c:949: warn: Creating new database...
[2012/09/14 09:54:28] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 10:20:48] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 10:20:48] minidlna.c:949: warn: Creating new database...
[2012/09/14 10:20:48] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 10:22:17] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/14 10:22:17] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/14 10:25:25] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 10:25:26] minidlna.c:949: warn: Creating new database...
[2012/09/14 10:25:26] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 10:28:22] upnphttp.c:929: warn: / not found, responding ERROR 404
[2012/09/14 10:28:28] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/14 11:06:52] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/14 11:06:52] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/14 11:09:59] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 11:09:59] minidlna.c:949: warn: Creating new database...
[2012/09/14 11:09:59] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 11:54:47] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/14 11:54:47] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/14 11:57:57] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 11:57:57] minidlna.c:949: warn: Creating new database...
[2012/09/14 11:57:57] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/14 11:58:38] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/14 11:58:38] minidlna.c:949: warn: Creating new database...
[2012/09/14 11:58:38] minissdp.c:107: error: bind(udp): Address already in use
[2012/09/14 11:58:38] minissdp.c:789: error: connect("/var/run/minissdpd.sock"): No such file or directory[2012/09/14 11:58:38] minidlna.c:1010: fatal: Failed to connect to MiniSSDPd. EXITING[2012/09/15 04:39:45] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/15 08:50:20] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/15 08:50:20] minidlna.c:949: warn: Creating new database...
[2012/09/15 08:50:20] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/15 09:00:59] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/15 09:00:59] minidlna.c:949: warn: Creating new database...
[2012/09/15 09:00:59] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/15 09:27:36] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 09:41:12] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/15 09:41:12] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/15 09:44:20] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/15 09:44:20] minidlna.c:949: warn: Creating new database...
[2012/09/15 09:44:20] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/15 10:03:37] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/15 10:03:37] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/15 10:06:43] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/15 10:06:43] minidlna.c:949: warn: Creating new database...
[2012/09/15 10:06:43] minidlna.c:1020: warn: HTTP listening on port 8200
[2012/09/15 10:09:30] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:09:40] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:09:50] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:10:00] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:10:10] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:10:20] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:10:30] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:10:40] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:10:50] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:11:00] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:11:10] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:11:20] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:11:30] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:11:40] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:11:50] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:12:00] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:12:10] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:12:20] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:12:30] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:12:40] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:12:50] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:13:00] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:13:10] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:13:20] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:13:30] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:13:40] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:13:50] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:14:00] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:14:10] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:14:20] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:14:30] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:14:40] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:14:50] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:15:00] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:15:10] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:15:20] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:15:30] upnphttp.c:969: warn: HTTP Connection closed unexpectedly
[2012/09/15 10:22:38] minidlna.c:158: warn: received signal 15, good-bye
[2012/09/15 10:22:38] minidlna.c:1314: error: Failed to remove pidfile /usr/pbi/minidlna-amd64/minidlna.pid: Permission denied
[2012/09/15 10:25:43] minidlna.c:926: warn: Starting MiniDLNA version 1.0.22 [SQLite 3.7.9].
[2012/09/15 10:25:43] minidlna.c:949: warn: Creating new database...
[2012/09/15 10:25:43] minidlna.c:1020: warn: HTTP listening on port 8200
- Status
