FreeNAS-8.0.3 How to disable SMBv1 ?
shlomi
I'm trying to disable SMBv1 in my FreeNAS servers.
Right now, Only workstations running SMBv1 can view shared folders from my FreeNAS server.
I want to increase the SMB version to SMBv2 at least.
I tried to put that line in the smb.conf:
min protocol = SMB2
and then execute:
/usr/sbin/service samba reload
It didn't help.
Thank you.
D
dlavigne
Guest
It's going to be hard to get a useful answer for a 5 year old version of FreeNAS running a 5 year old version of Samba...
shlomi
I thought about this to be honest..
Is it possible to upgrade the FreeNAS + samba version through the FreeNAS portal?
D
dlavigne
Guest
Not that far back. Save your config. Install the latest version to a new USB stick, then see if it lets you restore your saved config. If it barfs on the config, you'll need to recreate your configurations from scratch.
shlomi
I understand.
Thank you for the help, I will try it.
It almost certainly will. At the very least, jump to 9.2.1.9, then 9.3, then 9.10.2-U4 or 11 - and be mentally prepared to fix some permissions on Samba shares.
