Hi 2gether
SMB worked fine with FreeNAS 11.2 beta. After I've upgraded to FreeNAS 11.2 beta 2 SMB only works on NTLMv3. For my Ubuntu clients it is ok, I could specify "vers=3.0" in fstab and got it back to working state.
But I've got also two "old" Ricoh Copier/Scanning Machines (MP C2800/3300 and MP C5000). Those machines only support NTLMv1. After a firmware upgrade I could get them to work with NTLMv2, but not NTLMv3 - no way as I've read on the net.
I can't connect with Ubuntu Nautilus neither. I'm getting the error: org.gtk.vfs.Daemon[1636]: ** (gvfsd:1679): WARNING **: dbus_mount_reply: Error from org.gtk.vfs.Mountable.mount(): Failed to retrieve share list from server: Connection refused
If I check the box "NTLMv1 Auth" under Services -> SMB it doesn't work neither anymore (this still worked in the FreeNAS 11.2 beta 1 even though it's unsecure it was a workaround for getting the "old" copier machines to work with smb; so I prefer to update them and getting to work with NTLMv2).
But NTLMv2 should at least work? Where could be the problem that only NTLMv3 works?
My smb4.conf looks in the interesting part like this:
Thanks so much for your appreciated help!
P@sco
[global] server min protocol = SMB2 server max protocol = SMB3 encrypt passwords = yes dns proxy = no strict locking = no oplocks = yes deadtime = 15 max log size = 51200 max open files = 468812 logging = file load printers = no printing = bsd printcap name = /dev/null disable spoolss = yes getwd cache = yes guest account = nobody map to guest = Bad User obey pam restrictions = yes ntlm auth = yes directory name cache size = 0 kernel change notify = no panic action = /usr/local/libexec/samba/samba-backtrace nsupdate command = /usr/local/bin/samba-nsupdate -g server string = Server1 ea support = yes store dos attributes = yes lm announce = yes hostname lookups = yes time server = yes acl allow execute always = true dos filemode = yes multicast dns register = yes domain logons = no local master = yes idmap config *: backend = tdb idmap config *: range = 90000001-100000000 server role = standalone netbios name = SERVER1 workgroup = WORKGROUP security = user create mask = 0666 directory mask = 0777 client ntlmv2 auth = no dos charset = CP437 unix charset = UTF-8 log level = 1
P@sco
