FreeNAS 11 VMs?
Chris230291
So I created a VM yesterday. I added a CDrom and an ISO. I clicked start and it says running. However whenever I try to connect to the VNC my clients always say the host refused connection. Is there anything special I need to do? I see a lot of Coral guides, but I don't see most options in 11.
Now does "running" actually mean it's working? I remember when VirtualBox got removed I ran the check to see if my PC was capable of running the new system and it said it was not. Which is strange because Intels own sight seems to think my CPU should be(i7 860s) (virtualization is enabled in BIOS).
Any ideas?
SweetAndLow
Sweet'NASty
Any ideas?
That is basically all you have to do. Maybe add a zvol so you can actually install the os?
Chris230291
Ye something seems wrong. I cant connect and after several attempts the VM turns to "stopped". If I keep trying the server GUI is no longer accessible, but the server is still running. I have to ssh and restart to get the GUI back.
Any way to check my system is even capable of running it? I would assume that the "running" status suggests it is, but who knows?
Chris
Brer
How much mem did you assign? First time I created one in 11 I mistakenly set 2 instead of 2000 thinking it was in Gb and observed similar issues, Running but connection refused and eventually Stopped.
asc72
As Brer mentioned, make sure you are putting in MB instead GB. I got burned on that one as well. Also, try using tightvnc. Real VNC only connects when I first start my VM, but won't allow me to connect after.
SweetAndLow
Sweet'NASty
Hardware specs
Axemann
Hate to be a "me too"-er, but I'm have the same issue. I'm running 11-RC in a VMware VM, though, so all bets are off on what my root issue is.
I've assigned 4 vCPUs to the FreeNAS VM, enabled hardware virtualization pass through to it, and given it 12GB of RAM. Physical CPUs are E5620s.
I tried assigning 2 CPUs and 2048MB of RAM to the VM in FreeNAS, but always get the same result as OP. Looking at /var/log/messages, it appears that bhyve is core dumping as soon as I try to connect to the VM with any flavor of VNC.
Sent from my iPad using Tapatalk
Brer
Try running from the command line as follows, replace any variables with your own.
bhyve -A -P -H -c 1 -m 2 \
	-s 0:0,hostbridge \
	-s 31,lpc \
	-l com1,/dev/nmdm1A \
	-l bootrom,/usr/local/share/uefi-firmware/BHYVE_UEFI.fd \
	-s 3,virtio-net,tap0 \
	-s 29,fbuf,tcp=0.0.0.0:5902,w=1024,h=768,wait \
	-s 30,xhci,tablet \
	-s 4,ahci-hd,/dev/zvol/drive/vm/ubuntu/os Ubuntu
Obviously change tap0 to whatever yours is, usually tap0 but if you already have one then tap1. Replace drive/vm/ubuntu/os with the full path to your Dataset containing you Disk. Make sure your VNC Port is not in use, I have 5902, since I had Arch already running on 5902 I had to choose 5903 otherwise it failed.
Chris230291
My PC specs are an i7 860s with 16GB of RAM
What I assign to the VM is 1 CPU and 4000 MB of RAM
Osiris
I have exactly the same issue but found out that after a few tries, the vnc server seems to die.
A reboot of the FreeNAS host 'resolves' the issue.
Brer
I have had no issue of this kind, though I'm running an non-graphical arch Linux install.
I've been running Deluge, Deluge-web, OpenVPN (PIA flavour) and Plex Media Server in that 1 VM with 4 CPU's (Not really needed, I found 2 works for me just as well) and 2Gb RAM, this is the same setup with either Grub Boot loader from using Corral or UEFI using RC11. I don't think the host is the problem, maybe you are using too many resources in your VM.
