Nick Longo
- Jan 30, 2015
I've just updated to FreeNAS 11 from 9.10 today. Had some issues but worked through them.
I'm now trying to create my first VM. According to the FreeNAS UI it's now running and available at port 5901 VNC. I've read the users guide which stops at this point and been through the forums. Apologize if i'm missing this answer because it's quite basic.
From Windows I've tried my MobaXTerm VNC Client as well as TightVNC. I'm assuming the correct IP address is the IP of the FreeNAS machine. The port is identified by the UI as 5901 so VNC should be pointed at X.X.X.X:5901
When I try through MobaXTerm - it prompts for a password which from the forums doesn't sound like it should.
When I try from TightVNC - I get an explicit "Error in TightVNC Viewer: No connection could be made because the target machine refused it"
First - can any one confirm my assumptions on how to address the VM are correct?
Second - assuming I am correct, any other thoughts?
This is a new and my first VM, it's configured with a HDD (point to zvol) and CDROM (pointing to a linux installation .iso) along with the default NIC and VNC devices.
Thank you for the help.
