FreeNAS 11-U2 Missing plugins in left column of GUI
Terry Pounds
Does anyone know how to force plugins to appear in left column of GUI? As you can see in the image Sabnzbd is not showing on left in GUI. However, Sabnzbd is installed and functions normally. The issue is that when I go into GUI on the right side under plugins installed list I am unable to stop the Sabnzbd plugin by clicking the off and on button. I can stop and restart the Sabnzbd jail without issue though.
I would like to resolve this without deleting plugin and reinstalling if possible.
System Information
Hostname freenas-11.local Edit
Build FreeNAS-11.0-U2 (e417d8aa5)
Platform Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
Memory 15271MB
System Time Mon Sep 04 09:57:03 CDT 2017
Uptime 9:57AM up 17 hrs, 0 users
Load Average 0.33, 0.36, 0.31
Starlord
I have the same kind of issue, I have 2 plugins installed, I can see them in the legacy GUI but not un the new UI. I have Plex and Nextcloud both working fine but can't see them in the new GUI.
Did you found a solution?
8-bit Yoda
This is a rather old thread describing an issue with the legacy UI, before it was "legacy".
Your issue is quite different, and you already found the solution; Legacy plugins show in the legacy UI, and the new plugins show in the new UI. Read the release notes or this:
https://forums.freenas.org/index.php?threads/lost-jail-when-moving-from-11-0-to-11-2-beta.68644/
