freenas 11.3
William Bravin
hello all
i have too much time on my hands so i just upgraded to freenas 11.3 rc1 everything works well except emby jail. the old jail was constructed in 11.2 and worked fine.
so now i needed to rebuild the emby server. therefore i performed an (iocage clean -a ) in a shell before starting the process fine.
I have created a user called emby in freenas with full privileges.
so now i install the emby plugin
it will ask me what pool i want to use (my media pool is called media)
i enter the name emby as a name
release is 11.3
now there is the option to tick dhcp auto configure ipv4, Nat, vnet and berkeley packet filter everything with the exception of nat is checked
the only other ticked box is auto start and the jail auto starts fine I sometimes do not get an IP number for the jail when i do i get 192.168.1.237 which is fine.
I stop the jail to start adding mount points
this is where i have a problem
my window share is mapped as /mnt/media/movies (all in lower case)
so when i add a mount point to my jail i add as source /mnt/media/movies (all in lower case)
my destination i have /mnt/media/iocage/jails/emby/root/media/movies all is fine
now i want to add a folder called movies to the emby server
i add as server \\192.168.1.237
and in the optional share file /media/movies
when i go to sync emby will not load any movies ion to its server
what am i missing
please assist
thank you in advance
blueether
not sure about the emby error, buy why 11.3rc1 when 11.3u1 is already out?
William Bravin
thank you for responding it is 11.3.u1 my bad
The share in freenas are owned by wbravin
emby has wbravin as a user
freenas has user emby in emby group with full privileges
when i go to scan folders emby will not load any movies to its server The scan starts and stop immediately
It looks like a permission issue however i do not see what to change
what am i missing
please assist
William Bravin
hi solved thank you for your support
