MattTaylor2
- Oct 7, 2020
Hi all,
I am unable to create an SSH connection between our two FreeNAS boxes (Both on 11.3-U4.1). A static route has been created on host 1 and both connected interfaces show as active.
Have followed the documentation on how to create an SSH Connection and Keypair however when we try to "Discover Remote Host Key" the following error occurs:
(IP addresses and Hostnames obfuscated)
Below are the network settings for the NIC on host1:
Network settings for NIC on host2:
Output of netstat -rn host1
netstat -rn host2:
Both NICS are directly cabled together.
We have two other FreeNAS boxes that have the same setup as these two, and we have an SSH connection between these two for replication. It has a static route on host 1 as per the problematic NAS but I have noticed that in the routing table the gateway is set to "link#l" on the working NAS. When a static route is created via the gui on the NAS with the issue, the gateway in the routing table is set to host2 IP rather than "link#l".
/var/log/messages shows the following:
Any help would be much appreciated.
Thanks
Matt
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1084, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/keychain.py", line 509, in remote_ssh_host_key_scan
raise CallError(f"ssh-keyscan failed: {proc.stderr!r}")
middlewared.service_exception.CallError: [EFAULT] ssh-keyscan failed: "connect (`172.16.0.2'): Invalid argument\r\nconnect (`172.16.0.2'): Invalid argument\r\nconnect (`172.16.0.2'): Invalid argument\r\n"Below are the network settings for the NIC on host1:
root@hostname:~ # ifconfig
ix0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Replication
options=e407bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether a0:36:9f:5d:53:90
hwaddr a0:36:9f:5d:53:90
inet 172.16.0.1 netmask 0xfffffff8 broadcast 172.16.0.7
media: Ethernet autoselect (10Gbase-T <full-duplex,rxpause,txpause>)
status: active
ether a0:36:9f:60:7c:48
hwaddr a0:36:9f:60:7c:48
inet 172.16.0.2 netmask 0xfffffff8 broadcast 172.16.0.7
status: active
# netstat -rn Routing tables Internet: Destination Gateway Flags Netif Expire default *.*.*.* UGS lagg0 *.*.*.* link#8 U lagg0 *.*.*.* link#8 UHS lo0 127.0.0.1 lo0 UHS lo0 172.16.0.0/29 172.16.0.2 UGS ix0 172.16.0.1 link#1 UHS lo0
netstat -rn host2:
# netstat -rn Routing tables Internet: Destination Gateway Flags Netif Expire default *.*.*.* UGS igb0 *.*.*.* link#3 U igb0 *.*.*.* link#3 UHS lo0 127.0.0.1 lo0 UHS lo0 172.16.0.0/29 172.16.0.1 UGS ix0 172.16.0.2 link#1 UHS lo0
Oct 7 08:40:59 hostname kernel: arpresolve: can't allocate llinfo for 172.16.0.2 on ix0
Thanks
Matt
