Freenas 11.3 problems with no reporting on email and report hdd temp = 0 degress
Jedrek
Member
I successfully updated Frrenas from version 11.2-U7 to 11.3 Final. I have only two problems:
1. after the update, I don't receive any reports by email that I received when I had version 11.2-U7. I checked the settings and email test. Everything works, but I don't receive any reports. Reports can be previewed after logging in to the web of my device from Freenas. I would like to receive reports via email as usual.
2. HDD temperature indication does not work at all. I always have 0 degrees Celsius.
Can You help me ?
Chris Moore
Wizened Sage
Can You help me ?
Did you get a resolution to these difficulties? How is it working now?
Jedrek
Member
I have the latest version of FreeNas, but any resolution was working, my system not report any hdd temp, and reports not working anymore.
Chris Moore
Wizened Sage
@Spearfoot had to make some updates to the scripts that handle email to account for changes in the underlying software. Did you look at the thread for that:
He updated the scripts in the repository:
