Always the ZFS status is in DEGRADED mode.I tried to replace a new device,but it doesn't seem to be OK.The new device will set to be ONLINE status only for one or two days.Then it will be DEGRADED.
It hardly troubled me so much.Who knows how to solve this problem?
Here is the command line in Shell:
Last login: Wed Sep 2 14:30:40 on pts/6
FreeBSD 11.3-RELEASE-p11 (FreeNAS.amd64) #0 r325575+fb17f3e15b8(HEAD): Tue Jul 28 11:09:10 EDT 2020
FreeNAS (c) 2009-2020, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@BLISSFILMSTUDIO[~]# zpool status -v
pool: BLISSFILMDATA
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Wed Sep 2 13:48:00 2020
4.12T scanned at 975M/s, 2.15T issued at 507M/s, 29.5T total
551G resilvered, 7.27% done, 0 days 15:43:28 to go
NAME STATE READ WRITE CKSUM
BLISSFILMDATA DEGRADED 0 0 4.26K
raidz1-0 DEGRADED 0 0 9.66K
gptid/afef25cd-c421-11ea-89b7-ecf4bbe1a2c0 DEGRADED 0 0 0 too many errors
gptid/b0be1c7f-c421-11ea-89b7-ecf4bbe1a2c0 DEGRADED 0 0 0 too many errors
gptid/b0ca8b3d-c421-11ea-89b7-ecf4bbe1a2c0 DEGRADED 0 0 0 too many errors
gptid/b0d5a791-c421-11ea-89b7-ecf4bbe1a2c0 DEGRADED 0 0 0 too many errors
replacing-4 ONLINE 0 0 0
gptid/b0ef91f8-c421-11ea-89b7-ecf4bbe1a2c0 ONLINE 0 0 0
gptid/bd7457df-e01d-11ea-8b74-ecf4bbe1a2c0 ONLINE 0 0 0
gptid/0349f599-ddcd-11ea-bbc7-ecf4bbe1a2c0 DEGRADED 0 0 0 too many errors
gptid/b6587fe1-c421-11ea-89b7-ecf4bbe1a2c0 DEGRADED 144 504 3 too many errors
cache
gptid/8f76ba17-ce2e-11ea-9cce-ecf4bbe1a2c0 ONLINE 0 0 0
<metadata>:<0x103>
<metadata>:<0x133>
<metadata>:<0x137>
<metadata>:<0x138>
<metadata>:<0x8d>
<metadata>:<0xb2>
<metadata>:<0xb6>
<metadata>:<0xc0>
<metadata>:<0xf3>
<metadata>:<0xf7>
<metadata>:<0xff>
BLISSFILMDATA/.system/rrd-646f8dae97d646cc8946ddeb0ca79d97:<0x0>
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-6/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_counts-allocated.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_counts-mutex_miss.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_counts-stolen.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-7/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_demand-demand_data_misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_demand-demand_metadata_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_demand-demand_metadata_misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-9/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-9/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_evict-evict_l2_eligible.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-0/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-1/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-10/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_hash-hash_collisions.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-11/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_hash-hash_elements.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-12/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-13/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_hits_misses-hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-14/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_hits_misses-misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-15/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-16/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2-l2_feeds.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-17/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2-l2_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-18/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2-l2_io_error.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-19/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2-l2_misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-2/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2-l2_rw_clash.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-20/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-21/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2_compress-l2_compress_successes.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-24/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-25/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2bytes-l2_read_bytes.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2bytes-l2_write_bytes.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-29/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-3/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2write-l2_write_buffer_iter.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2write-l2_write_buffer_list_iter.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-4/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-6/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-8/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2write-l2_write_not_cacheable.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cputemp-9/temperature.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/ctl-ioctl/disk_octets-0-0.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2write-l2_write_pios.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/ctl-ioctl/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2write-l2_write_spa_mismatch.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2write-l2_write_trylock_fail.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_l2writes-l2_writes_sent.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_mru-mfu_ghost_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_mru-mfu_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_mru-mru_ghost_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_prefetch-prefetch_data_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_prefetch-prefetch_data_misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-root/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_size-data_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-root/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_size-other_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfid0/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_size-size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfid0/disk_ops.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd0/disk_io_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-DATA/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd0/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-DATA/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd0/disk_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-TEMP/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-TEMP/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd1/disk_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd2/disk_io_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd2/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-OUTPUT/df_complex-reserved.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd2/disk_ops.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-OUTPUT/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd2/disk_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd3/disk_io_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd3/disk_ops.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd4/disk_io_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd4/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd4/disk_ops.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-download/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd4/disk_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd5/disk_io_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-images/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd5/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd5/disk_ops.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-images/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd5/disk_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd6/disk_io_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-jails/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd6/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd6/disk_ops.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-jails/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-mfisyspd6/disk_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-nvd0/disk_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-nvd0/disk_ops.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-log/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/disk-nvd0/disk_time.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-releases/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/geom_stat/geom_busy_percent-nvd0.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-releases/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/geom_stat/geom_latency-nvd0.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-templates/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/geom_stat/geom_ops_rwd-nvd0.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-templates/df_complex-reserved.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-templates/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/interface-igb0/if_packets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nut-ups/voltage-battery.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-0/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-1/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-10/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/interface-ix2/if_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/interface-ix2/if_packets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/load/load.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/memory/memory-active.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/memory/memory-cache.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/memory/memory-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/memory/memory-wired.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-12/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-12/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nfsstat-client/nfsstat-fsinfo.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-12/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-13/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-13/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-download-11.3-RELEASE/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-13/cpu-nice.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-download-11.3-RELEASE/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-download-11.3-RELEASE/df_complex-reserved.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nfsstat-client/nfsstat-pathconf.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-14/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nfsstat-client/nfsstat-readirplus.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-14/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nfsstat-client/nfsstat-remove.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-16/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-16/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nfsstat-server/nfsstat-create.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-releases-11.3-RELEASE/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-releases-11.3-RELEASE/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-16/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-17/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nfsstat-server/nfsstat-getattr.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-releases-11.3-RELEASE-root/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-releases-11.3-RELEASE-root/df_complex-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-18/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/df-mnt-BLISSFILMDATA-iocage-jails-NextCloud/df_complex-free.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-18/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/nfsstat-server/nfsstat-readlink.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-19/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-19/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-19/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-19/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-2/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/interface-bridge0/if_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-2/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/interface-vnet0.1/if_packets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/processes/ps_state-running.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/interface-bridge0/if_packets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/processes/ps_state-sleeping.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/interface-vnet0.1/if_octets.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-20/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-20/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/processes/ps_state-zombies.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-20/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-21/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/rrdcached/operations-receive-flush.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-21/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-22/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/swap/swap-used.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-22/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/uptime/uptime.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-23/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_eviction-eligible.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-23/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_operation-allocated.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-24/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-24/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_ratio-arc.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-demand_data-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-demand_data-miss.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-24/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-demand_metadata-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-25/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-demand_metadata-miss.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-mfu-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-mfu_ghost-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-mru-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-25/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-mru_ghost-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-26/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-prefetch_data-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-26/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-prefetch_data-miss.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-prefetch_metadata-hit.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_result-prefetch_metadata-miss.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-26/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-L2.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-27/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-anon_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-27/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-arc.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-27/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-27/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-c_min.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-28/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-hdr_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-metadata_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-mfu_ghost_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-28/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-mfu_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-28/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-mru_ghost_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-29/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-29/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/cache_size-p.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc/hash_collisions.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-29/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_arc-hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-3/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_arc-l2_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-30/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_arc-misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_data-demand_data_misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_data-prefetch_data_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-30/cpu-user.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_metadata-demand_metadata_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_metadata-demand_metadata_misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_metadata-prefetch_metadata_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-31/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_metadata-prefetch_metadata_misses.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-4/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-4/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_mu-mru_ghost_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/arcstat_ratio_mu-mru_hits.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-4/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw-l2_hdr_size.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-5/cpu-idle.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-5/cpu-interrupt.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/cpu-5/cpu-system.rrd
/var/db/system/rrd-646f8dae97d646cc8946ddeb0ca79d97/localhost/zfs_arc_v2/gauge_arcstats_raw_arcmeta-arc_meta_used.rrd
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:10 with 0 errors on Fri Aug 28 03:45:10 2020
NAME STATE
http://freenas.org
Welcome to FreeNAS
pool: BLISSFILMDATA
state: DEGRADED
cache
<metadata>:<0x103>
<metadata>:<0x133>
<metadata>:<0x137>
<metadata>:<0x138>
<metadata>:<0x8d>
<metadata>:<0xb2>
<metadata>:<0xb6>
<metadata>:<0xc0>
<metadata>:<0xf3>
<metadata>:<0xf7>
<metadata>:<0xff>
pool: freenas-boot
state: ONLINE
NAME STATE
